Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
4th gen to 3rd gen swaping questions!!!
Old Oct 19, 2010 | 12:05 AM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
i believe that this would be the right area to post these questions since there not motor or trans related.. if not any mod that wants to relocate this please feel free to..
im hopefully pickin up a 99 ss parts car.. its a complete car that was totaled out from an accident.. anyway besides the motor, transmission, rear end, gas tank, dash, seats, and door panels what else can be swaped from a 4th gen into my 3rd gen vert?
also i plan on using the stock harness from the parts car since im going to be swapping the complete motor, trans, dash and all.. so im hoping to plug and play except for the head and tail lights which i already figured i would have to wire in to the new dash..what else do i need to keep from my 91 harness??? this is the most important question cuz i already have the harness out and ready to sell!!
these are what i have in mind that i would like to swap
front brake assembly? since im going with a tubular kmember and control arms.. fuel lines? brake lines? brake booster? master cyl? steering setup? driveshaft? anything else????
i know about the dash swaps and door panels and all that but im talking about unbolting them from the parts car and bolting them in on the vert.. mainly the brake up grades and fuel lines.. im trying to use as much as i can from the parts car so i dont have to buy more stuff.. leaveing for the military in january and really want my baby atleast being able to move under her own power since when i get back i will only have a few weeks to pack up and go to my new post and wont have time to finish car untill i get settled where ever that may be..
Old Oct 19, 2010 | 08:10 AM
hale.stephen66's Avatar
Re: 4th gen to 3rd gen swaping questions!!!
when i put a 454 in my 89 camaro can i use the stock big block exhust
Old Oct 19, 2010 | 08:33 AM
Firebat's Avatar
Cat back exhaust, outside door handles, outer window sweeps, radiator, coolant tank, window washer fluid tank, radiator shroud with dual fans if you use 4th gen rad, rear sway bar,
From a lt1 trans am - the spoiler, sideview mirrors, and door side moldings.
Old Oct 19, 2010 | 10:02 AM
Engine: ls1 soon
That's good to know. I knew about the radiator and stuff just forgot to list it. But I was looking more towards suspension components and other items that are used to make the car run and drive.
Old Oct 19, 2010 | 10:06 AM
Engine: ls1 soon
Leaning more towards the lsx series motors.. inless ur talking about an lsx 454. I'm hoping that with the tubular kmember I will have enough room to run the long tube headers that are comming with the ls1 parts car
Old Oct 19, 2010 | 12:14 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Everything in the rear suspension will bolt on your car. The front calipers, pads, and rotors are the only front end parts that will fit from the brakes or suspension. I believe the master cylinder will fit, but not 100% sure of that.
Pretty much all of the interior can be made to fit. The seats are the only real "bolt-in" parts though. Everything else like the dash, door panels, center console, etc needs at least a little bit of work to make it fit.
Old Oct 19, 2010 | 02:05 PM
Engine: ls1 soon
great thats what i wanted to hear! i already knew that the interior pieces would take some work to fit but thats the fun of it all.. now how about the carpet? fuel lines? brake lines, even tho im probably ganna go steal braided anyway.. anyone know where to get the steel braided lines? not looking for just the covers i want the actually lines from front to back of the car.. will look nice with my fully coated underbody and make install alot easyier then hard lines.. thanks guys keep the info comming and ill be sure to post tons of pics during my swap which im hopping only takes me a few weeks to switch entire car over once i get the parts car here.. lotta long night ahead of me
Old Oct 19, 2010 | 06:45 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
for the brake lines and fuel lines, try inlinetube, thats were i got mine and they fit perfect
http://www.inlinetube.com/
Old Oct 28, 2010 | 12:34 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Originally Posted by Firebat
outer window sweeps
Really? i haven't even noticed that
booster and masters fit, though i heard with the ls1 booster the rods are longer or shorter or some damn thing. also the 4 studs that you use to bolt to the firewall are a smaller diameter but its not really to much of a problem as far as the masters the ls1 works with stock lines the lt1 you have to use adapters. im running a LT1 booster with a LS1 master with the stock 3rdgen lines and prob valve.
here is some compares i took.
more pics of them and the boosters found here at post #227
https://www.thirdgen.org/forums/memb...y-start-5.html
Old Nov 5, 2010 | 02:41 PM
FueledSoul's Avatar
bump on outer 4thgen window sweeps, sold both my 4thgens so i cant just go out and compare them
Old Nov 5, 2010 | 03:17 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Check out this thread:
https://www.thirdgen.org/forums/auto...-solution.html
Old Nov 9, 2010 | 01:21 PM
FueledSoul's Avatar
Thanks!
Old Nov 9, 2010 | 03:48 PM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
If you are swapping the dash, you can use every inch of wire from the ls1 car. It would add a tiny bit of extra work, but it would save from having to make/buy a conversion harness. That's what I did on my car...from headlights to tail lights, my car has 4th gen ls1 wiring.
Old Nov 9, 2010 | 05:04 PM
$750 L98's Avatar
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
You can definitely do a full dash swap if you like the new look. If you want you can also use all your old dash and gauges. I believe the 1991 was all electric? Should just be a matter of hooking up the wiring. I bet you could even make your fuel gauge work with the 4th gen tank (I did on my firebird). If you go that route, search for my fuel gauge thread and see if you can apply the modification to your camaro gauge. (I am going to find one locally and see if I can dream something up eventually)
Old Dec 22, 2010 | 12:38 PM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
I am trying to install a LT1 master on my 82 TA. Can anyone tell me what size fittings I need to install the lines from the valve to make the lines work. I went to a few shops around here but they didn't have anything in stock.
69 Six Pack
Oct 5, 2015 07:51 PM
jbd1969
Aug 17, 2015 07:06 PM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
reiderz iroc
Aug 13, 2015 04:57 PM
