Finally a window sweep solution!!!
Old May 4, 2009 | 04:25 PM
charlielamb's Avatar
Car: 1991 formula
Engine: 350 tbi
Axle/Gears: 308 posi
so i got sick of my old cracked window sweeps and didnt feel like spending $100 bucks on new ones so i went to the junkyard and paid 5 bucks for 4th gen window sweeps i had to modify them and cut them but they worked and they look nice let me know what you guys think Finally a window sweep solution!!!-101_0027.jpg
Old May 4, 2009 | 04:42 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: Finally a window sweep solution!!!
looks good! can we have the details on how you had to modify them?
Old May 4, 2009 | 05:36 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Looks good... Is that a Lemans/Gto in the car reflection?
Old May 4, 2009 | 07:53 PM
85_ZED28's Avatar
Car: '85 Z28
Cool, any more details?
Old May 5, 2009 | 07:57 AM
Car: 1991 formula
Engine: 350 tbi
on the front of the sweep i cut off about 3/4 inch and then lined it up with the rear and cut to size then i had to line up the holes from the previous sweeps thats on the door skin and drill it out and screw it in, the lemans in the background is my dads we redid the car over the winter
Old May 5, 2009 | 08:02 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I wish i had seen this sooner. I would have been all over doing this because there are two fourth gens at the junkyard at the moment.
Old May 5, 2009 | 11:56 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
how well does it seal to the glass, I think i like the looks better. You would think that since our sweaps are mostly straight someone would make universal sweaps that could be cut and drilled to fit.
Old May 5, 2009 | 12:02 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
oooooohhhhh... going to the junkyard tonight!! yay. thanks!
Old May 5, 2009 | 03:12 PM
Car: 1991 formula
Engine: 350 tbi
i forgot to mention that the 4th gens use small metal clips to hold the sweeps on instead of screws so they have to be removed in order to work
Old May 5, 2009 | 03:15 PM
drtask's Avatar
Car: 1988 Camaro RS
Engine: 2.8L V6
thats pretty damn smart. i'll be going to the junkyard this weekend!
Old May 5, 2009 | 03:27 PM
Car: 1991 formula
Engine: 350 tbi
the only problem i ran into is that the 4th gen window sweeps have a slight arc in the shape of them but if you screw them down it will bend it back down
Old May 5, 2009 | 03:29 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
i have that same socket set...
oh, and cool.
good info.
mine are almost completely gone so i will be doing this soon
Old May 6, 2009 | 08:03 AM
Car: 1991 formula
Engine: 350 tbi
the old window sweeps will help as a template to drill holes in the new ones
Old May 6, 2009 | 08:25 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
I didn't see a responce earlier, do they still seal really well against the window? Also they look taller, is it unconfortable to drive around with your arm out the window? Hitting the yards this weekend, may grab a few sets.
Old May 6, 2009 | 08:56 AM
Car: 1991 formula
Engine: 350 tbi
they seal up decently but with the window adjusters you can snug it up closer
Old May 6, 2009 | 05:11 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
That is an excellent example of a resourceful person. Good Job! I spent over 12 hours scouring junkyards this past Saturday and I got to wondering if they would fit. I didn't get any because I have a brand new set of GM sweeps that I'm fixing to put on after the new paint.
Old May 8, 2009 | 07:49 AM
Car: 1991 formula
Engine: 350 tbi
anyone else try this yet?
Old May 9, 2009 | 10:37 PM
alkyzgro's Avatar
Car: 85 Z28 & 84 Trans Am
Engine: 305 / 350
Transmission: T5 / 700R4
Axle/Gears: 10bolt 4.10 / 9bolt 2.77
Several months back while at the U-Pull-it i took some off a white 4th gen, they were in excellent condition and i figured i could take them and try and fit them on my 85. I think i also paid 5 bucks for the pair.
Now that i know someone has gotten them to fit I know what i'll be doing next weekend. Thanks for the tip!
Old May 11, 2009 | 07:01 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
you should post this in the 4th gen compatability thread that is a sticky so it will be easier for people to find it.
Old May 12, 2009 | 07:37 AM
jg04222's Avatar
Car: '82 Z-28
Engine: 355
Transmission: TH-400, 8" ATI MRT
Axle/Gears: Moser 9", 4.56's
I did this this weekend. i messed the first one up, because i cut the excess off of the rear of the sweep, instead of the front. If you cut all of the excess off of the front then the notch for 4th gen mirror/triangle seal will line up better with the triangle piece. If you cut if all off of the back like I did on the first one you end up with a long 1/4" gap between the window and the factory cut out for the 4th gen triangle seal. I went yesterday and got a new one to redo the drivers side. there is only a small gap (like 3/16") between the edge of the triangle and the sweep. I think this gap could be eliminated if I didn't cut as much off of the front, which would move the sweep back some and you could then cut the back to fit, but I wanted to keep the factory cut on the back because you can see it. with a razor blade i can cut a small portion out of the transition spot where it contacts the triangle piece, and you won't be able to see it because of the mirror.
I wish I would have seen this post earlier, because the o.p. says to cut some off of the front and then trim the rest off of the back , not cut all off of one side like i did. anywho this is a good mod in my opinion and it's not that hard to do. mine seal very well against the window, and not to mention they're like 15 years newer than the originals that were on my car.
Old May 12, 2009 | 04:06 PM
madhatter's Avatar
wish i thought of it, but new ones, and paid a fortune
Old May 25, 2009 | 06:39 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Very interesting, has anyone else tried this yet ?
Old May 25, 2009 | 10:28 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
i did it, i trimmed all the extra off the front to avoid exposing the inner metal at the end of the door, and trimmed back the flap so it all lays nice behind the mirror...
getting the screw holes lined up right can be tricky, and getting to the screws behind the glass required the screw driver bit held in a vise grip approach but it was worth it
Old Jul 24, 2009 | 05:20 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
OK - this is great!
But - did anyone carry it another step yet and try to mod the inners to the top of our door panels to fit?
Old Oct 11, 2009 | 03:38 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
Just did this a couple weeks ago, very easy and very cheap. Too help with getting to the screws behind the top of the window, I drilled out the backside bottom stop(rubber was gone and I was going to replace with the rubber bike brake) and took out the top adjustors (things with the felt on them). This lets you get the window down farther and also you can pull the window to you to get more room.
I also used bigger new self tapping screws with a hex head on them so I could handle them better with the drill. Also no need to use the original holes, I got the piece cut close held it in place and drilled a pilot at the backside and put a self tapping in. Then just work your way forward. After I got all the screws in I took a straight cut tin snips trimmed the ends.
After all is said and done the 4th gen sweeps make good contact and I think the bigger strip of rubber looks better than the tiny stock stuff.
Old Oct 11, 2009 | 10:42 PM
usamuscle892's Avatar
Car: 1992 Z03 RS
Engine: (L03) 305TBI
Transmission: TH-700R4
Axle/Gears: bone stock
Thanks for the tips! Us junkyard dogs always get the last laugh.
Old Oct 12, 2009 | 03:03 AM
bj350hp's Avatar
Car: 1987 Camaro SC
Dude! Thanks for saving me 200 bucks very nice dude!!
Old Oct 12, 2009 | 03:13 AM
Hooyah's Avatar
I'm gonna try it too this weekend ill be posting results and pics, thanks for havn a brain bro.
Old Oct 12, 2009 | 09:12 PM
Car: 1991 formula
Engine: 350 tbi
yep my car has nice paint and wheels but the window sweeps just ruined the whole apperance, and me being the cheap a$$ i am didnt feel like dishing out the money for new ones lol
Old Apr 28, 2010 | 01:51 PM
Awesome-X's Avatar
Car: 87 Camaro
So did you try the inner ones too, or just the outer ones?
Old May 3, 2010 | 11:43 PM
Car: 1991 formula
Engine: 350 tbi
i never tried the inner ones
Old May 9, 2010 | 08:00 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Nice job!
Old Feb 27, 2011 | 04:33 AM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
i did this a little while ago and going to give away my secret for the triangle piece where the seal doesn't meet up and seal my body guy gave me a piece of 3m seal thats has an adhesive side and just trimmed it and stuck it under the well at the edge of the seal so its out of sight and it takes up the gap and seals tight otherwise if you leave this gap your letting any water run down in the down and i just painted and fixed rust and rot and was worrying about making a new problem
Old Mar 3, 2011 | 01:08 PM
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
What is the forth gen window sweep made of? Is it like the third gen made of rubber?
Old Mar 3, 2011 | 01:44 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
I saw a How To thread about doing the 4th gen windows sweeps yesterday.....
https://www.thirdgen.org/forums/body...ml#post4834928
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
3rdgenkindagal
Sep 29, 2015 01:41 AM
Fronzizzle
Sep 8, 2015 12:10 PM
scottmoyer
Sep 7, 2015 07:06 PM
