Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Anyone heard of this?
Old Mar 22, 2011 | 12:33 PM
Demon355's Avatar
Emachineshop/
I want wheel caps for my Ronal rims and came across this.
Old Mar 23, 2011 | 04:45 PM
jt1562000's Avatar
Car: '88 IROC-Z
Engine: 383 Stroker
Re: Anyone heard of this?
I have used this a few times. As long as you are good with making a correct 3-d picture and inputting the correct sizes it works great. Watch material selection though, some can get very expensive fast.
Old Mar 23, 2011 | 05:07 PM
Demon355's Avatar
Yeah I did a few test pieces and was amazed at the cost. Trying to make wheel caps for my Ronal rims. Could use some help!
Old Mar 24, 2011 | 08:03 AM
jt1562000's Avatar
Car: '88 IROC-Z
Engine: 383 Stroker
I can program it all for you if you can send me some ideas of what you are looking for and sizes you need.
Old Mar 24, 2011 | 09:34 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Ive used them. They are quite good if you have no other options for fabrication. They can be VERY expensive for just a small order. Materials and accuracy of machining both play a part in just how expensive...
I wanted to use them to make some simple aluminum plates for window switches...and unless I ordered 20 or more, it was pretty steep. But Ive done some other things through them and it was really reasonable.
J.
Old Apr 6, 2011 | 10:06 PM
MFaust89's Avatar
Car: 88 IROC-Z / 92 z28
Engine: LB9 / sbc of a station wagon
Transmission: 700R4 / t5.6
Axle/Gears: i have 2 now!!
you should have posted on ccfbg. pm if you need help. I only work with SolidWorks for 3D an idea, a cap is gonna need some crazy tolerances (depending on type of fit you want)
Old Apr 6, 2011 | 11:56 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The Ronal r15 lug/center caps aren't that impressive a fit in the tolerance department.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Jan 10, 2020 08:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mcbitchman
Sep 29, 2015 12:32 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
