Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Subframe Connectors
Old Jun 30, 2011 | 06:03 PM
LETSROC's Avatar
Car: 1985 IROC-Z
Subframe Connectors
I have a 85 IROC and I'm looking 4 a diagram on how 2 make subframe connectors 4 my car. Hope someone can help me out with this.
Old Jun 30, 2011 | 06:42 PM
Steel Armadillo's Avatar
Car: '85 Sport Coupe/Z28
Engine: N/A 350
Transmission: TH350
Axle/Gears: Factory 10-bolt w/3.08
Re: Subframe Connectors
https://www.thirdgen.org/forums/susp...questions.html
Hopefully this will help.
-Steel
Old Jul 1, 2011 | 01:50 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
There simple.
Old Jul 1, 2011 | 04:40 PM
Engine: N/A 350
Transmission: TH350
CE connectors are 2"x2"x0.082", if that helps as well.
Old Jul 10, 2011 | 08:10 PM
RCR3's Avatar
Car: '91 Z28, '04 2500HD
Engine: 5.7
Here is a pic. of the subframe connectors I made. I used 2" channel that was 1" tall. I used 3/16 or 1/4 plate in the back to go between the pinch weld and the control arm mount. The drivers side can be straight, but I made the passenger side match the contour of the floor. I used the channel because it is the same height as the pinch weld and doesn't hang down. They cost me $50 in steel and one night to fab up.
Attached Thumbnails Subframe Connectors-may05_0001.jpg   Subframe Connectors-may04_0004.jpg
Old Jul 10, 2011 | 09:15 PM
FueledSoul's Avatar
Here is the ones i made
Old Jul 10, 2011 | 11:44 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
FueledSoul, those look badass! They're like the UMI and Alston's in one.
Old Jul 11, 2011 | 01:02 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
nice work!
Old Jul 12, 2011 | 12:25 AM
FueledSoul's Avatar
Thanks, not really they just flow the bends and curves of the floor pans.
FueledSoul's Avatar
Originally Posted by TPI TERR
nice work!
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
