Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
LT1 Composite valve covers fitment??
Old Jul 17, 2011 | 07:37 PM
dfarr67's Avatar
Tough to know what forum to stick this in. Bought a pair to LT1 valve covers and I can't get them to work- although stock tin covers work fine?? I run RHS vortec heads with Comp 1.6 steel roller rockers. I have removed the drip tabs but the LT cover seem to be 1/4in shifted towards the intake, and when running seems to have rocker interference. I'm all about go and less show, the intention was to quieten the rockers somewhat- but otherwise they really look good.
Old Jul 17, 2011 | 09:36 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: LT1 Composite valve covers fitment??
My LT4's seemed to move them towards the exhaust side. Don't seem to rub but can't say for sure as I have yet to fire the engine. Also, I couldn't get the recommended gasket to seat right, so I shoemakered a tin set.
Attached Thumbnails LT1 Composite valve covers fitment??-dscf2058.jpg   LT1 Composite valve covers fitment??-dscf2045.jpg
Old Jul 18, 2011 | 08:16 AM
dfarr67's Avatar
Took me some time to find a complete set- too bad. I never thought about retrofiting the old gaskets. I would say they probably would fit fine on stock heads but I've had some other issues with the RHS- oil leaks because some of the bolts would not seat all the way. What rockers are you using? What do you mean by 'seat right'?
Old Jul 19, 2011 | 01:41 AM
watajob's Avatar
Car: 92 T/A 'vert
1.6 S/A Scorpions. The gaskets kept popping out when I tightened them down, like the distance from the inside edges of the rails were a coupla' thousandths less than a stock head. As far as the gaskets, there's a Fel Pro number for them. I just walked in and bought them. Is there a difference between the LT1 and LT4 gaskets? The store manager assured me there wasn't but maybe that was my problem. Just fill the groove in the valve cover and a little extra with RTV, clamp them down, let 'em dry over night and you should be golden. They sit flat so I'm hoping they'll seal OK. I'll let you know.
Old Jul 19, 2011 | 08:02 AM
dfarr67's Avatar
Yes do that- I'll be waiting. I wonder if mine were louder because on the intake side they were overhanging and left a nonsealing space.
Old Jul 23, 2011 | 06:31 PM
dfarr67's Avatar
Good call, seems to work for me.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
Amillionoh7
Sep 5, 2015 11:44 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
