Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
relocate tank fill up to back of camaro
Old Aug 16, 2011 | 11:23 AM
trujalej's Avatar
i dont like the look of the fuel door on my 91 rs and i was wondering if relocate it behind the rear license plate is a good idea like a caprice or monte Carlo has it
Old Aug 16, 2011 | 11:36 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: relocate tank fill up to back of camaro
sure as long as you can weld the filler neck onto the tank and built a giant trunk section to separate it from the passenger compartment. Might be easier to explode the tank too if you're ever hit from behind
Old Aug 16, 2011 | 11:49 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Running the filler tube directly through your back well makes this difficult. I wouldn't bother.
customblackbird
Aug 15, 2021 10:16 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
