Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
My 4L80E swap
Old May 21, 2010 | 04:00 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
My 4L80E swap
Hi...
One of the things I'm doing right now is putting in a 4L80E tranny instead of the TH700.
I have LT headers and a homemade y-pipe, also using a adjustable torque arm from spohn.
The Tranny next to the TH700.
List of things...
* 4L80E
* Driveshaft
* 1350 to S44 Joint since I still have stock rear
* Vigiliante Convertor
* TCI Box
* Sligthly massaged the tunnel with a hammer
* New crossmember
* Torque arm modified.
Old May 21, 2010 | 04:08 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Re: My 4L80E swap
The first thing is to get it up, no big deal only had to massage one place since the 4L80e has a two bumps at right side at the back with holes in them...The first one hits the floor, se If I can take a picture of it.
After getting it up the torque arm seemed to be at the same lenght as the tranny mount, making it hit the strut, something had to be done...
2 alternatives...
1. shorten the torque arm but then I have to weld a new y-pipe and exhaust...Then It would be hard to sell since the torque arm would only fit my car...
2. Make it longer so it would be in front of tranny mount....
I went with nbr 2.........
next thing is to weld a new crossmember...........coming soon
Old May 22, 2010 | 05:55 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Re: My 4L80E swap
I drilled out the far rearest holes in the frame, welded some M10 nuts on a piece of sheetmetal and then welded the piece on to the frame so that I have two "threded" holes in the frame at the rear.
I then did a piece of iron like this
This is the main part of the new crossmember. I didnt want it to hang in just 2 bolts in case of one should loose so I added some sheetmetal toward the std holes in the frame, also added torque arm mounting and some reinforcements.
Old May 22, 2010 | 03:10 PM
83 Crossfire TA's Avatar
Re: My 4L80E swap
I take it that you just hammered the floor in there? are they the 2 lumps that are staring right at you in this picture:
Old May 22, 2010 | 03:12 PM
Re: My 4L80E swap
have you done anything to the tranny or is it stock? What stall PI? Is it the 3 disk?
Old May 22, 2010 | 03:19 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Re: My 4L80E swap
yes, the front one hits the floor, Will take a picture of it and post.
Tranny is modified to the "worst", also line pressure is controlled with vacuum and not by the TCI box.
Vigil is a multi disc, bought is used, have to check if its a 3disc or 5disc
Stall rpm in former owners car was 5k, will se what it stalls behind my engine ....
Old May 22, 2010 | 06:43 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Re: My 4L80E swap
Interesting.. Be sure to post some pics. Fitment is a worry for me.
Old May 22, 2010 | 08:40 PM
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
Re: My 4L80E swap
LOL I was just talking about doing a 80 in my bird yesterday LOL really interested in this especially because I'm gonna pick one up tomorrow.
Old May 23, 2010 | 12:22 PM
Re: My 4L80E swap
Worst? Vacuum? HUH?
5 disk? Mine has a 3 disk clutch which according to them is rated for 1600hp (hp ratings) and 3500 stall.
Old May 24, 2010 | 02:04 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Re: My 4L80E swap
Maybe "best" would be more correct *lol* . Dont have a full spec but It can take som abuse ....
A full weight 4gen camaro used this setup for 3-4 years before it needed rebuild, raced alot and best times was 9,4 I think.
Yes, line pressure is controlled by vacuum. Will post more pictures tonight (swedish time )
Old May 24, 2010 | 11:39 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Re: My 4L80E swap
Pictures
Here is where I massaged the floor
One more with the tranny slightly down
Modified bracket for Wire, this is so I can use my y-pipe
Tranny cooler lines
NPT to AN 90deg + 45deg AN - Hose
NPT to AN straight + 90deg AN to hose
Crossmember
Old May 26, 2010 | 02:00 AM
Re: My 4L80E swap
What year is the Trans?
Old May 26, 2010 | 02:03 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Re: My 4L80E swap
Dont know.....
Is there any nbr on them? that would help I can check it out....
Old May 26, 2010 | 02:26 AM
Re: My 4L80E swap
I'm not sure about any year stamp or not. The 80 I picked up was 03 model and the trany lines are different from what I can see . Gotta take it down to the trany Guy tomorrow LOL it looks funny sitting between the bars for the cage
Old May 30, 2010 | 11:04 PM
Re: My 4L80E swap
are the cooler lines really NPT, or do you have some sort of adaptors in there?
Old May 31, 2010 | 01:53 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Re: My 4L80E swap
I used NPT to AN fittings.
I didnt re-use the old lines, I used hose with AN hose ends.
The electric hook up is almost ready, Its starting to be alot of wires now on the passenger side. 165-730 conversion, dual WBO2, EGT, TCI box.....
Old May 31, 2010 | 06:18 PM
Transmission: 4L80E
Re: My 4L80E swap
I'm stock form with shiftkit how much abuse can a 4l80e take? 400-500hp? I enjoyed your write up. Gonna be putting a 4l80 in my car when the Turbo systems done
Old May 31, 2010 | 06:22 PM
Re: My 4L80E swap
4l80e in stock form is rated at 440 (mt1) & 460 (mn8 )
Old Jun 1, 2010 | 12:08 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Re: My 4L80E swap
F*ck....I mounted the Y-pipe today and it sits so high and the 4L80 tranny is so much wider than TH700 so the shifter arm hits the exhaust
I dont want to lower the y-pipe so I'll try to make a new shifter arm, cable holder.......
Old Jun 2, 2010 | 01:06 PM
Transmission: 4L80E
Re: My 4L80E swap
That sucks. So... Put transmission in then build Y pipe, lol. I got that luck
Old Jun 11, 2010 | 12:22 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Re: My 4L80E swap
Problemo solved
I placed the shifter arm upside down and put a longer cable in from the front instead from the rear......
Took some testing before I got the cable in correct place so the shifter was smooth to move between all gears in both directions.....
So Its all there now, next questions is how is the VSS signal from the 4L80e ? Time will tell....
Old Jun 11, 2010 | 12:40 AM
Re: My 4L80E swap
Hey looks good the way I understand the vss thing is you need a buffer box and you use the sensor on the back of the Trans
Old Jun 11, 2010 | 05:37 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Re: My 4L80E swap
I use the stock buffer box, EPROM set to 4000ppm.
more to come soon
Old Jun 21, 2010 | 05:57 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Re: My 4L80E swap
VSS Now tested speedo showed 60mph just idling out if the garage.....
This is with VSS buffer box hooked up so If you still use a 1227165 ECM you'll need some kind of adjustable "buffer box" to slow down the signal.
Since I have a 1227749 ECM with magnetic vss signal input I rewired it last night, removed the VSS box and hooked up vss/speedo/CC direct to the ECM, will test it this week.
Old Jul 4, 2010 | 11:47 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Re: My 4L80E swap
Now everything works.
I removed the stock VSS Buffer and replaced it with a DRAC/VSSB from a Astro van, modified it like suggested on this site http://www.tbichips.com/drac/
and now everything works. Tuning left but thats another story...........
Old Jul 5, 2010 | 12:18 AM
Re: My 4L80E swap
That's great to hear
what year vssb /drac did You use and are you running a factory speedometer
Old Jul 5, 2010 | 12:54 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Re: My 4L80E swap
I got one from 92-95 a so called VSSB with "dual bank of jumpers".....
And yes using factory speedo.
Oh, one thing make sure the TCI box gets enought power!
Was testing a WOT run yesterday and the car didnt shift, Fuse blow (10amp) since I had dual WBO2, EGT and some otherstuff also on same fuse and TCI-box only should have 10Amp fuse. Well I let off and got home in 2'gear but the car ran good up to 6375rpm to bad I didnt get any WBO2 readings......
Old Jul 5, 2010 | 02:01 AM
Re: My 4L80E swap
So
the the vssb box runs the speedo directly?
Old Jul 5, 2010 | 02:22 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Re: My 4L80E swap
yes, there are both 2000ppm and 4000ppm outputs on it.
/N.
Old Dec 7, 2010 | 09:57 PM
Re: My 4L80E swap
Nice test drive video
Old Aug 19, 2011 | 02:49 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Re: My 4L80E swap
Especially the part where he has to check the floor mat... LOL
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
