Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Volt meter
Old Aug 18, 2011 | 01:26 PM
Mr P's Avatar
Volt meter
Have had a little battery and alternator problems so I want a little eye on the power in the car so I put a digital volt meter today.
Old Aug 18, 2011 | 01:53 PM
INTIMIDATOR Z's Avatar
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
Re: Volt meter
thats pretty nice. hows the actual gauge look behind the plastic?
Old Aug 19, 2011 | 08:16 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Volt meter
Your key is out, so the IGN is off and the gauge is still lit up. Your battery wont last long
Whats the point of a numeric gauge a few inches away from the analog gauge?
Old Aug 19, 2011 | 08:24 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Volt meter
that was my question too.
Old Aug 20, 2011 | 05:23 AM
Mr P's Avatar
Re: Volt meter
I had a button that did not work in the panel and had a voltmeter loose so I put it there. I know there were two voltmeter. Maybe it will be deleting it soon.
Old Aug 21, 2011 | 12:22 PM
85_ZED28's Avatar
Car: '85 Z28
Re: Volt meter
Did you make the trim rings around the gauges?
Old Aug 21, 2011 | 01:37 PM
Mr P's Avatar
Re: Volt meter
Yes I have made rings around the gauges
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
