Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Pitot tube (pressure gauge)
Old Aug 25, 2011 | 09:00 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
im only putting this in the fab section due to the fact the tube has to be fabbed into the ram air box, anyone know of a company that makes this gauge? used to measure air pressure among other things. im interested in installing an extra gauge that measures the ram air pressure inside a custom box to design a box that works over 60-70mph. thanks
Old Aug 28, 2011 | 08:57 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Pitot tube (pressure gauge)
Use a standard pressure gauge, lowest range you can find. If you saw 2psi at 150mph with the throttle slammed shut Id be surprised
Something like this
http://www.grainger.com/Grainger/MIL...&cm_vc=IDPBBZ2
Old Aug 29, 2011 | 07:06 AM
Something like this
i knew id get something from you jon, i read up a 12 page article on 2 C5's compared side by side, one stock, one with a ram air, the RA'd C5 picked up 26 rwhp over the stocker(supposedly the RA effect begins to take place at 75mph with .09 psi which equates to about 1.7 hp and compunds with increased psi from increased speed). they recommend a guage that reads in .10's of a psi to even gauge the effect, that link you posted looks like it might work but where or what should i use as a sensor? obviously it needs to be tapped into the box, id assume closer to the TB as i can since thats where the effect takes place but im not sure where to start, just something different i wanted to try out.
Old Aug 29, 2011 | 04:07 PM
Pocket's Avatar
Car: 91 Trans Am
Port it directly to the box. If the box is seeing pressure, the gauge will read it
mike_c
Aug 27, 2015 04:32 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
