fuel fittings
Car: 70 Chevelle
Engine: 396
Transmission: TH350
Axle/Gears: 10 bolt 3.73
fuel fittings
since fuel cells dont seem to be an option for these cars without major modification. would it be possible to have fittings welded to the bottom of the tank for a braided fuel lines to connect to? if so where could i buy them?
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: fuel fittings
can it be done? yes. you'll probably have a hard time finding someone who will weld on your gas tank, though.
Car: 1987 Trans Am
Engine: LQ9/L92
Re: fuel fittings
if you have someone who will weld for you, you'll want something like this added to the tank
http://www.summitracing.com/parts/CEE-4041/
http://www.summitracing.com/parts/CEE-4040/
just make sure to get the right size fittings for whatever you plan on running for lines.
evilstuie
Jan 9, 2020 08:29 PM
R3500
Aug 17, 2015 12:16 PM
