Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
LS1 Motor Mount Adapter Plates
Old Sep 4, 2011 | 10:35 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
anyone know the specs of the mounts that bolt onto the side of an LS motor? i've searched and searched and nothing, so i've decided to fab up a pair... if i could find a measuring tape i'd measure it myself, but i can't... i plan on using my stock SBC mounts adapted to the ls motor...
Old Sep 13, 2011 | 09:24 AM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
Re: LS1 Motor Mount Adapter Plates
try over at ls1tech.com i'm pretty sure they have templates in the stickys
Old Sep 13, 2011 | 09:37 AM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
http://67-72chevytrucks.com/vboard/s...d.php?t=413855
the best I have ever found on info about the mounts ect
Old Sep 13, 2011 | 09:50 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
that is one heck of a good source for info, great find.
when building these, do bear in mind you want to go with the 1" setback style if you want to keep the engine and trans in the same spot as the factory sbc was. the standard or non-offset will move it forward and give you more grief when it comes to the kmember clearance (although you should still notch it for the 1" back as well for some extra breathing room).
Old Sep 13, 2011 | 09:56 AM
lunati397's Avatar
I put a 6.0 in a 62 and it was very helpfull to me then and hands down the best resource I have ever found on LSX mounts for swaps
Old Sep 13, 2011 | 09:57 AM
lunati397's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=456787
this will give you just about everything you would need to find
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
