Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Another tail light idea- with pic and ???s
Old Sep 6, 2011 | 06:47 PM
Horn0816's Avatar
Car: '92 RS
Engine: GM 350 swap
So I've been looking into this red turn signal thing and some people do the reverse lights too. I was wondering if there was anything in the black filler part other than the license plate light. Has anyone ever put a 4x1.5 clear light in there for reverse lights. In my state I don't need reverse lights, but when I get my back glass tinted it sure wouldn't hurt to have reverse lights. I threw a picture together in paint and it looks pretty killer.
Attached Thumbnails Another tail light idea- with pic and ???s-tail-lights.jpg
Old Sep 6, 2011 | 07:21 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Another tail light idea- with pic and ???s
im actually considering doing this exact same thing and running STS and flash 4 bulbs (including the corner bulb)
Old Sep 6, 2011 | 09:16 PM
Horn0816's Avatar
Car: '92 RS
Engine: GM 350 swap
I'm thinkin about STS also, but I wanted to keep it legal. The corners have to be reflective for when your car is parked and not on so that other drivers can see it. Unless you wanted to put reflectors elsewhere...
Old Sep 6, 2011 | 09:22 PM
travis401's Avatar
Car: 91 Camaro RS
it would still reflect like it does now, it would just flash as a 4th bulb with the turn signal as well.
Old Sep 7, 2011 | 10:41 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Looks like it's trying to get closer to the look of a Mustang with the 3 red segments....
I like amber turn signals, so I would leave the tail lights alone, but if I was to do something like this I definitely would not move the reverse light.
Old Sep 7, 2011 | 11:39 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
I changed my turn signal lenses to red and wired a Trans Am tail light harness into it to make them both act as brake lights and turn signals like the TA's do. Only did half of the back up light so it illuminates both red and white when in reverse
Old Sep 8, 2011 | 12:02 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
There is nothing behind those black panels between the lights & license plate, other than the license plate lights. No reason you can't turn that section into a reverse Light.
Turn that into a Reverse light lens & either have 4 Reverse lights lenses for more light, or red out the stock ones to had more red for your tail lights.
Old Sep 9, 2011 | 09:52 PM
Horn0816's Avatar
Car: '92 RS
Engine: GM 350 swap
That's what I was looking for, thanks BlackenedBird.
Now I just have to find a light that fits...
Old Sep 10, 2011 | 04:34 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
I thought about this too last year. I drilled a hole and put a tag light housing facing backwards with a bright *** led bulb for temporary use when i switched to 3 bulb sequentials. Now I have 2 led strips on the bottom of the plate.
Old Sep 13, 2011 | 02:28 PM
92RSsleeper's Avatar
Car: 92 Camaro
Engine: 404 SBC
Transmission: The strongest stock T5 ever made
Axle/Gears: 3.73 w/Detriot Tru Trac Locker
That's really pretty slick looking I really wanna see a finished product from someone
Frozer!!!
Jan 19, 2024 04:55 PM
project89
Sep 24, 2015 06:38 AM
Jk_Under
Sep 2, 2015 10:59 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
