Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
A few interior pieces i made for mine
Old Sep 15, 2011 | 11:24 AM
87ta415's Avatar
Car: 87 T/A
Engine: 415ci dart SBC
Axle/Gears: dana60 3.73 gears
Center console i made from sheet metal. Hand bent, welded all together and finished and painted. Has a acc. outlet and both window switches and a trap door inside to access the wiring. Switch panel is 6061 aluminum i made and drew up. Buddy of mine painted it for me.
Made a custom fuse/relay center to run all aftermarket items up under the dash where the fresh air inlet door used to be. All relays and switches are seperately fused to avoid any problems.
Kind of a bad pic but took my original cluster and cut the entire guts out to leave the frame and made this aluminum piece and used all factory holes to mount it up.
Old Sep 15, 2011 | 11:30 AM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: A few interior pieces i made for mine
nice fab work
Old Sep 15, 2011 | 12:19 PM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Looks AWESOME!!!
Old Sep 15, 2011 | 12:58 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Lots of patience!!
Nice job!!
Old Sep 15, 2011 | 02:12 PM
87ta415's Avatar
Car: 87 T/A
Thanks guys. It actually didnt take real long to make any of the pieces. A little focus and the wife leaving me alone for a while makes it easy!! LOL
Old Sep 21, 2011 | 10:09 PM
Firebird_305's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L TBI
Transmission: Automatic
I really love how the console came out! I am going to do the same with mine, sheet metal and paint black. It will be a nicer and cheaper method than hunting down a center console. Very nice car, can't believe how great it looks! By the way, where did you get those gauges? Thinking of doing the same with mine, sheet metal and using new aftermarket gauges. What was the difficulty for wiring them?
Old Sep 22, 2011 | 11:30 AM
87ta415's Avatar
Car: 87 T/A
They are autometer ultra lite 2 1/16 and 5in dash tach. I made my own wiring harness for all the lights and fuel level and volts. I did it so only a power and ground come out the back of it and 1 connector for the fuel level. Everything is attached to the back of the aluminum panel i made.All the gauges are on a switch from my fuse/relay board.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
Street Lethal
Aug 14, 2015 08:25 PM
Street Lethal
Aug 12, 2015 11:33 AM
