Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Gear-Shift Cover?
Old Sep 23, 2011 | 11:31 AM
mdelancy91's Avatar
Car: '92 Camaro Z28 25th A/E
Engine: 350ci 5.7L TPI
Gear-Shift Cover?
Not too sure if I'm posting this in the right place or not (sorry if I didn't!), but I'm looking to see if anyone knows if the shift cover for an auto shifter is something I can find to replace mine that's all been cracked away over the years. I'm working on restoring the interior and would like to cover the hole...
Any help is greatly appreciated.
Old Sep 23, 2011 | 03:38 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Re: Gear-Shift Cover?
Here's a tip: EVERY PART in your car can be replaced. Even the VIN, in some special cases. Start looking around at wreckers or classifieds for thirdgens being parted out. If you actually want to fabricate a new shifter plate, it could be as simple as cutting out a piece of sheet metal to the shape of the console and drilling the correct holes.
Pac J
May 17, 2020 10:44 AM
skinny z
Oct 5, 2015 06:23 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
Dragonsys
Sep 25, 2015 03:51 PM
