Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Cowl hood question
Old Sep 27, 2011 | 08:33 PM
endo666's Avatar
Car: 84 Camaro
Transmission: Stock 5 Speed
Cowl hood question
I have a 4" cowl hood on my 84 camaro. I want a plate to block of engine heat to the air filter and to seal the to the inside of the cowl like the picture below.
does someone sell these or do i need to make one from scratch. I know i will probably have to modify one that i buy to make it work but i want a starting point.
Cowl hood question-chevrolet-camaro-z28-eng
next question I may try to trade my 4" cowl for a 2" cowl and if i do that i want to make a shaker induction. i have seen some do the shaker from the 2nd gen camaro but as crazy as it sounds i like the shaker on the 04 body style ford mustang mach 1. has anyone tried that before?
any comments or suggestions.
Old Sep 27, 2011 | 09:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Cowl hood question
There may be a few generic kits available but they're always cut and modify to fit. Most of the air pans I've seen are always custom made.
Old Oct 3, 2011 | 03:48 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
You probably won't be able to find the pieces you're after, but it shouldn't be too hard to make one up yourself. Mock it up with cardboard and masking tape, measure and trim until you get the right shape and fit, maybe leave a gap to allow for movement, then use the mockup as a template for fiberglass or sheet metal, whichever you're more comfortable working with.
Old Oct 3, 2011 | 07:35 PM
wretched737's Avatar
Search it, there was another thread with a bunch of pics
Old Oct 3, 2011 | 08:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you will be making this yourself, there are no kits that would work, besides, every cowl hood brand is made differently.
this is what i had made by a friend for ym car
Old Oct 3, 2011 | 08:45 PM
endo666's Avatar
Car: 84 Camaro
New idea. my uncle and i are going to turn my hood into a ram air hood. cut a hole of some sort up at the front possibly a chey emblem. then use some sheet metal to seal the air cleaner.
Old Oct 3, 2011 | 11:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Any plans on driving in the rain? That's why cowl hoods are more popular on street cars.
I run a scoop because it's a track only vehicle. It grabs a lot of air and at about 100 mph, I can see the back of the hood lifting up.
Old Oct 4, 2011 | 05:56 PM
one92rs's Avatar
Car: SOLD!!!!!
love the an fittings on that engine.
Old Oct 4, 2011 | 07:43 PM
endo666's Avatar
Car: 84 Camaro
Im sure there are ways to help keep rain out or minimize it.
Old Oct 4, 2011 | 08:04 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Work on that before deciding on a front mounted opening. Installing a baffle system to reduce or eliminate water from entering will probably also reduce or eliminate the ram air effect. Pulling air from the base of the windshield is just as effective without the hassle.
Old Nov 11, 2011 | 08:30 PM
T_Revor0012's Avatar
a stop sign and an old couch cushion(for the foam) and make it to suit yourself
Street Lethal
Apr 30, 2019 12:14 PM
LittleFranks
Aug 20, 2015 03:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
