Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
gfx ????/
Old Oct 28, 2011 | 08:50 AM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
gfx ????/
wanting to know if these are the right measurements for the 91-92 rear rocker panel brackets i'm trying to have them fabricated. the entire bracket is 5.5in x 2.25in with the other cuts for the bottom portion which is 1.75in x 1.75in is this close? I bought some camaro gfx and at the time did not know that this bracket was supposed to come with it.
Attached Thumbnails gfx ????/-img-20111028-00055.jpg
Old Nov 1, 2011 | 12:08 PM
Car: 91RS
Re: gfx ????/
got the pieces made now on to the bolts. does anyone know where i can find the speed nut bolts that came on the oem brackets?
Old Nov 2, 2011 | 03:59 PM
Car: 91RS
Re: gfx ????/
update got the pieces made and they are way too thick (i think). .25in steel is alot thicker than the oem metal was has anyone tried this? will it work? does anyone know? or can help? if these don't work I will use my grinder and slowly start taking off layers. if you have a better idea please share it.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Sep 17, 2015 12:22 PM
snakeshooter
Sep 7, 2015 11:15 AM
LittleFranks
Aug 20, 2015 03:55 PM
