Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Pop-up deletes that look good
Old Dec 15, 2011 | 01:18 PM
  #101
sjgrimsley's Avatar
Car: 2008 C6 / 1982 Trans Am
Engine: LS3 / Hybrid LS1-406 SBC
Transmission: 6L80 / 4L60E
Axle/Gears: 2.56:1 / 3.23:1 4th gen Posi
Re: Pop-up deletes that look good
Yes, there are plenty of quad bi-xenon retrofits but they are expensive and very hard to aim. Lol
The 24x conversion is awesome. My 406 with XE268H cam idles at 625 in P/N and 575 in gear. Dead smooth. No hiccups stumbles or stutters. I love it. And being able to change spark, fueling, and shift points at will is amazing. I have my car running OLSD at the moment because the O2 sensors are useless with the overlap of this cam and I haven't recalibrated the MAF yet. I think it beats the hell out of what I read about TPI and TBI ecu's and such.
Old Dec 15, 2011 | 06:03 PM
  #102
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Well basically I was just gonna get 2 bi-xenon kits and combine them lol. Sweet! you just convinced me lol. I wanna do it to mine with a monoblade throttle body
Old Dec 15, 2011 | 06:45 PM
  #103
sjgrimsley's Avatar
Okay that will be a ton of light so 50w ballasts. Make sure you use 35w ballasts. You will have a true 70w output with quad projectors.
And that's what I've got is the monoblade 78mm throttle body. Most don't like DBW for some odd reason but I love it lol makes cruise control so easy and seamless.
Old Dec 15, 2011 | 08:56 PM
  #104
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Alright sweet, thanks for the info.
And my CC don't work:/
Old Dec 15, 2011 | 10:29 PM
  #105
sjgrimsley's Avatar
Mine didn't either. As long as your stalk has +12v going to it and the cruise switches work, then cruise will work with dbw.
Old Dec 16, 2011 | 08:35 AM
  #106
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Well I think that is the problem is my switch, bc the intermediate wiper doesn't work, low/high setting works, high beams work, cruise control don't work. I have a new wiper motor and pulse module on it and all correctly installed and plugged in right
Old Dec 16, 2011 | 10:36 AM
  #107
sjgrimsley's Avatar
How clean are the connections under the hood for the wiper motor and all? Mine don't have very good connections and need new pigtails completely. They work fine unless the car has sat out in the rain for a while then the wipers go crazy. Lol
Old Dec 16, 2011 | 12:57 PM
  #108
sjgrimsley's Avatar
PICTURE UPDATE:
That's right, I finally got some more pics to post! Lol
Okay so here we go:
Okay. I know, finally. Lol
Old Dec 16, 2011 | 08:20 PM
  #109
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
There clean, I cleaned everything before I put it back together.
Old Dec 16, 2011 | 08:21 PM
  #110
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
That looks sweet! picture from front level with the lights would be great as well lol
Old Dec 16, 2011 | 08:32 PM
  #111
sjgrimsley's Avatar
I can get that tomorrow maybe haha got a bunch of Christmas stuff going on.
Old Dec 16, 2011 | 09:07 PM
  #112
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
haha alright, yep know how that is. Mall is packed, only had to get a ring for my gf and took me 45 minutes:/
Old Dec 16, 2011 | 09:09 PM
  #113
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
also do you have the lights hooked up and workin? how is the visibility?
Old Dec 16, 2011 | 09:18 PM
  #114
sjgrimsley's Avatar
Yea I've been meaning to get some output shots on the road and some wall shots but never think about it. I get too distracted by all the light. Lol.
Old Dec 16, 2011 | 10:16 PM
  #115
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
lol. I bet its a huge improvement over stock P.O.S lightin lol
Old Dec 16, 2011 | 10:22 PM
  #116
sjgrimsley's Avatar
Actually I was very happy with silverstar sealed beams but the glare to other drivers was horrible so I didn't keep them.
Old Dec 17, 2011 | 01:25 AM
  #117
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Thank you for being considerate to other drivers.
Ultimately when you blind oncoming drivers you endanger their lives and your own and you'll just as likely end up in a head-on crash as they will.
Old Dec 17, 2011 | 01:43 AM
  #118
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Maybe it was just the aiming of yours? I live way out in the country on DARK roads (no red lights, not street lights, not even front yard lights) and I have yet to EVER be brighted with my Silverstars in the last 3 years since I started running them, so mine haven't bothered anybody bad enough to tell me, not even the cops.
Old Dec 17, 2011 | 10:38 AM
  #119
sjgrimsley's Avatar
I aimed them like they are supposed to be aimed and the glare was horrible. Then I aimed them very low and it was still as bad. It's just too much light for a reflector based headlight. Also the silverstart sealed beams are the only ones that offer any improvement in light. 9005 bulbs and such are crap. So if you didn't have sealed beams all you had was whiter light. And no one ever flashed me like that but a friend told me they were too bright behind him so I got my dad to drive down the road and back and I saw how bad it was over stock. It didn't look like brights but it looked like a lifted pickup.
Old Dec 17, 2011 | 11:53 AM
  #120
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
So I shouldn't get the silver stars?
Old Dec 17, 2011 | 12:35 PM
  #121
Car: GTA
I've had them for 3 years & love them. Direct drop-ins so MUCH cheaper & easier than Projector HIDs. H4s in conversion lamp housings are a waste of $.
Old Dec 17, 2011 | 01:24 PM
  #122
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Got a part # and where I can get em?
Old Dec 17, 2011 | 01:29 PM
  #123
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
never mind found em. Is there any difference between the silverstars and xtravision?
Old Dec 17, 2011 | 07:00 PM
  #124
sjgrimsley's Avatar
BlackenedBird is correct. You'd probably be very happy with the silverstars. The one and only reason I didn't keep them was because of the glare. And the H4 conversions ARE junk.
Here is the front shot you wanted:
The lenses are visible in certain light such as this. I think it looks kinda cool tho.
Old Dec 17, 2011 | 07:06 PM
  #125
sjgrimsley's Avatar
Oh and output shots are on the way. I have the driver's seat and part of the console removed at the moment chasing down some wiring issues with the BCM I put in from the Tahoe. My driver's seat belt buckle doesn't have the plug in for the seat belt warning mess and I'm trying to wire that up to work with the BCM chime and the light in the dash. The door sill retractor has a plug in on it but I don't know what that's for.
Old Dec 17, 2011 | 10:26 PM
  #126
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
dang thats sweet, really can't tell they are there. great job. yes I will be going with silverstars soon
  #127
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
haha i can tell the driver seat is out lol
Old Dec 18, 2011 | 09:11 PM
  #128
sjgrimsley's Avatar
dctrouant1995, do you know what the connector on the driver's side seat belt retractor on the door sill is for?
Old Dec 18, 2011 | 09:54 PM
  #129
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
I honestly don't know. I have no clue what it could be, the only connector that i know for sure what is, is on the buckle which lets you know when you do or don't have your seatbelt on. My best guess would be sensor to lock up the retractor if you slam on brakes or get in a crash.
Old Dec 18, 2011 | 09:55 PM
  #130
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
hope that helped
Old Dec 18, 2011 | 10:11 PM
  #131
sjgrimsley's Avatar
That's what I was thinking as well. I'd assume that it is a +12v connection for a solenoid that is self grounded by the mounting bolt. I put +12v on it momentarily, but nothing happened. My car has no part of the harness going to it. This seat belt set is from an '85 Trans Am, whereas mine is an '82. The odd thing is I had the dash in from the '85 and it has the light in the dash for "Fasten Seat Belts" just as the '82 dash. Yet, there is no part of the harness under the carpet for this.
Old Dec 18, 2011 | 10:27 PM
  #132
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Was there a wire going to the bolt? Being honest unless your state has inspesctions, I wouldn't worry about it. Its a 20 somethin y.o car, nothing is going to work or be like they used to be. How long does the fasten your seatbelts stay on? mine only stays for a few seconds even of the belt is plugged in. I have an 88 T/A
Old Dec 18, 2011 | 10:39 PM
  #133
sjgrimsley's Avatar
There's no wire to the bolt. I was only curious what it is for.
The fasten seat belts reminder has never worked. In the quest to make this car feel as modern as possible inside, I have the body control module from a 2000 Tahoe all wired up. The seat belt reminder is part of it and I would like for it to function. Little subtle things like that help the car not seem 30 years old. Lol. The auto dimming mirror is also one of these things. The retained accessory power (part of BCM) helps as well (radio stays on for 15 minutes after you kill the car, fyi). I love having these little modern touches in the car if you can't tell. Lol
Old Dec 19, 2011 | 07:57 PM
  #134
sjgrimsley's Avatar
The seat belt chime works now. Lol. I need a relay for the telltale to work though.
Old Dec 19, 2011 | 09:46 PM
  #135
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Dang, great job wanna come help me do that to mine lol, or tell me how you wired everything and what you used, could stand to with out the seat belt chime, glad that doesn't work, but the radio I wouldn't mind doing
Old Dec 19, 2011 | 09:52 PM
  #136
sjgrimsley's Avatar
How to wire up the bcm? It's really easy. Just need the pinouts and match everything up that you want to use. The bcm needs power ground and ign. It doesn't have to 'talk' to the computer to still work. I even wired up the remote keyless entry from the same vehicle. Even tho I don't have power locks.. lol
Old Dec 19, 2011 | 09:58 PM
  #137
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Alright sweet, everything on my car is power. I will have to try this when I have the interior apart
Old Dec 19, 2011 | 10:57 PM
  #138
sjgrimsley's Avatar
I have the BCM under the dash to the left of the steering column. I had to add 4 relays total: retained accessory power (RAP), parking lamp relay, headlamp relay (these two are for auto headlamps), and courtesy lamp relay. I need to add one that cuts power from the headlamps when it's being cranked so the HID's don't flicker. Oh yea, and I need to add the one for the seat belt telltale lol. The seat belt switch is a switched ground. The lamp in the dash is switched voltage. Hence, the relay. I can't use the BCM to control the lamp because it's only output for warning lights is thru the Class II Serial Data wire. Our gauge clusters don't have this. But, I can use that when I do my dash swap!
Old Dec 19, 2011 | 11:02 PM
  #139
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Dang I may not do that lol, don't know that much, but havin automatic pop ups would be cool for me. I don't like the seatbelt warner, i know when I do and don't have my seatbelt on lol
Old Dec 19, 2011 | 11:05 PM
  #140
sjgrimsley's Avatar
Is your reminder a chime or a buzzer?
Old Dec 20, 2011 | 05:58 PM
  #141
Mike92Firebird's Avatar
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
Sorry I totally disappeared from this thread. Haven't been on TGO for a bit. The lights look great! Should be ordering mine in a week.
Old Dec 20, 2011 | 09:34 PM
  #142
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
mine is a chime. I have no life lol, im on here all the time lookin thru threads
Old Dec 21, 2011 | 11:48 AM
  #143
sjgrimsley's Avatar
Lol same here.
Don't worry about it I wander away from tgo sometimes too. Haha.
Old Dec 21, 2011 | 03:04 PM
  #144
sjgrimsley's Avatar
Yesterday I made a circuit with two relays. One to keep the headlamps off while cranking and the other for the seat belt telltale. I wired it into the car today and it works just as expected.
This is the BCM tucked away behind a bunch of it's wiring. Haha
The auto headlamps don't come on until the car has started now and the seat belt reminder telltale works.
Old Dec 21, 2011 | 06:09 PM
  #145
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Haha awesome, good job, love the lablelin lol
Old Dec 21, 2011 | 09:20 PM
  #146
sjgrimsley's Avatar
Oh yea. Gotta label. Lol.
Old Dec 21, 2011 | 09:39 PM
  #147
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
lol thats where i mess up, i cant read my writin most of the time lol so jus take pics and match it up best i can lol, if it don't match up, mayb it wasn't to important haha
Old Dec 21, 2011 | 10:16 PM
  #148
sjgrimsley's Avatar
No, you gotta take your time! Lol
Old Dec 21, 2011 | 11:26 PM
  #149
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
lol, i aint good at that
Old Dec 22, 2011 | 04:20 PM
  #150
sjgrimsley's Avatar
Here's somewhat of an output shot.
