Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Pop-up deletes that look good
Old Dec 22, 2011 | 06:30 PM
  #151
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: Pop-up deletes that look good
Dang thats bright
Old Dec 22, 2011 | 06:46 PM
  #152
sjgrimsley's Avatar
Car: 2008 C6 / 1982 Trans Am
Engine: LS3 / Hybrid LS1-406 SBC
Transmission: 6L80 / 4L60E
Axle/Gears: 2.56:1 / 3.23:1 4th gen Posi
It is. 50w is overkill.
Old Dec 22, 2011 | 06:47 PM
  #153
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
haha i like it, mayb i could c at night
Old Dec 22, 2011 | 07:14 PM
  #154
sjgrimsley's Avatar
It's too much light for my eyes and I'm only 20. 35w would be much easier on my eyes. Over driving those bulbs makes them yellower as well. You just can't tell in that pic.
Old Dec 22, 2011 | 07:32 PM
  #155
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i agree, i used 35's in my car and they are more than enough. and oncoming drivers can still see where they are going...
Old Dec 22, 2011 | 08:21 PM
  #156
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Yea thats one thing i don't like is driving at night and having someone comin toward you or behind you with super bright lights
Old Dec 22, 2011 | 09:13 PM
  #157
sjgrimsley's Avatar
Over the cutoff there is still zero light. Coming at you, there is no difference between 50 and 35 watt. The difference and what makes it too bright is when I'm meeting someone at the top of a hill. Then it's too bright.
I have seen it coming at me as it sits and there is actually less glare than our '10 RS/SS Camaro. Those are OEM 35w projector setup.
Old Dec 22, 2011 | 09:36 PM
  #158
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Usually it isn't the brightness, just the glare, and how they are angled
Old Dec 22, 2011 | 09:48 PM
  #159
sjgrimsley's Avatar
That's the beauty of projectors
Like I said, less glare than the new Camaro. Well, pretty much any vehicle for that matter. They are very easy on the eyes.
Old Dec 22, 2011 | 09:55 PM
  #160
sjgrimsley's Avatar
These pics were taken with all the settings on the camera on manual, all the same.
^^See, this is above the cutoff. The foreground is still very very visible. Relatively no glare.^^
This is below the cutoff. Extremely intense. This is what I'm worried about and why I say 50w is overkill:
Old Dec 22, 2011 | 10:51 PM
  #161
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
mayb it won't be to bad to other drivers
Old Dec 22, 2011 | 11:00 PM
  #162
sjgrimsley's Avatar
It's not. As long as they stay above the cutoff.
Old Dec 23, 2011 | 01:27 AM
  #163
Mike92Firebird's Avatar
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
Great output! I can't even imagine how this would feel driving compared to OEM setup at night.
Old Dec 23, 2011 | 01:46 AM
  #164
sjgrimsley's Avatar
It's like having the sun mounted in a big *** reflector aimed all the way down the road. Lol. That's how it feels anyway.
Old Dec 23, 2011 | 01:53 AM
  #165
Car: 89 GTA
Engine: 5.7 TPI L98
Haha I'm sure that's what you were shooting for anyways! I think I'll try the 35w setup when I first install mine.
Old Dec 23, 2011 | 01:59 AM
  #166
sjgrimsley's Avatar
Good choice. I'll soon be stepping down to Morimoto 3five ballasts.
Old Dec 23, 2011 | 02:03 AM
  #167
Car: 89 GTA
Engine: 5.7 TPI L98
Haha so it seriously is too much light right now? Or are you just scared of blinding people who find themselves above the cutoff?
Old Dec 23, 2011 | 09:00 AM
  #168
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
thats what i would worried about is blind other drivers, i don't wanna wreck and im sure they don't either lol
Old Dec 23, 2011 | 12:39 PM
  #169
sjgrimsley's Avatar
It seriously is too much light. It is too hard on the eyes when there is no other ambient light. After long drives at night my eyes feel strained, and sometimes I even catch myself squinting. Lol.
Old Dec 23, 2011 | 06:17 PM
  #170
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
really? I don't drive mine that much at night, unless I have to, I can't see very well at night
Old Dec 23, 2011 | 06:46 PM
  #171
sjgrimsley's Avatar
Yea projector hids are so much better than sealed beams its no comparison. 35w with good projectors is all you'll ever need.
Old Dec 23, 2011 | 07:05 PM
  #172
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Sweet, well for now, i'll upgrade to the silverstars then later i'll do the hid projectors
Old Dec 23, 2011 | 08:39 PM
  #173
sjgrimsley's Avatar
Alright that sounds like a plan lol
Old Dec 23, 2011 | 08:56 PM
  #174
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
lol hopefully
Old Dec 23, 2011 | 09:54 PM
  #175
sjgrimsley's Avatar
Just go with FX-Rs and 35w ballasts. You'll be happy.
Old Dec 24, 2011 | 10:19 AM
  #176
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
alright thanks, where did ya get em? and get 35 instead of 50 right?
Old Dec 24, 2011 | 11:43 AM
  #177
sjgrimsley's Avatar
Yes. 35 instead of 50. Www.theretrofitsource.com.
Old Dec 24, 2011 | 02:18 PM
  #178
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
I think it would be cool to put em in the fog light housing
Old Dec 24, 2011 | 02:20 PM
  #179
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
what relay should I use on the projectors?
Old Dec 24, 2011 | 02:47 PM
  #180
sjgrimsley's Avatar
That's too low to the ground. Probably not legal either.
Any 30 amp automotive relay should do just fine.
Old Dec 25, 2011 | 12:22 AM
  #181
Car: 89 GTA
Engine: 5.7 TPI L98
I've been bitten by the retrofit bug!
https://www.thirdgen.org/forums/fabr...ml#post5130764
Old Dec 25, 2011 | 06:07 AM
  #182
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Well I saw it had a blazer fog light projector kit, it has a bunch of different relays to choose from, 9006 and a bunch of H#
Old Jan 12, 2012 | 12:57 PM
  #183
overide's Avatar
Originally Posted by 85FBTranam
Don't know how this was done, but a pretty slick factory look to this install.
That looks like the redraif style headlight mod...
I wanted to do the same style install but wanted to keep the stealth factory look when they were off. My thoughts were to install a piece of tinted plexi in front of the lights or lightly nightshading them. But I was worried about the light output being reduced. Around the time that install hit here on tgo, HIDs were not as big as they are now or as attainable on a decent budget. So recently I have rethought about about doing reds install but going with HID bulbs in the housing to overcome the tinted lens... decisions, decisions
Old Jan 13, 2012 | 01:43 AM
  #184
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
I was the one who did the pop up deletes on the first page of this thread. Thanks for the kind responses.
The light output on those projectors is pretty good, the look of the deletes is pretty good as it helps that your using the stock covers, but the look of the single projector still bothers me (hence Why I went with a 2nd halogen projector for my 2nd design). I found that the height of the projector FX-R is a good bit taller than the morimoto mini H1's that i ended up going with. Basically a 30mm difference in height. Also all HID projectors are NOT sealed, halogen projectors are fully sealed but you can not fully seal a HID projector as too much heat is produced. The open space allows cool air to cool the bulb and housing. By decreased the height of the projector you could have increased the height of the lense (Compared to how much is getting cut off from the bumper) which will put more light on the ground right in front of the bumper. You should take some pics on level ground of the light output within the first 15ft of the bumper.
Im running the morimoto mini H1 projectors with H1 8000K bulbs with a 55W DDM slim digital ballasts. The 55W kit will wash the bulbs color out and it will appear more like a 5000-6000K bulb. Ive also used 35W ballasts (first design) with Hella halogen projectors and the light output was decent, but nothing compared to the 55W kit. Honestly Dont think you could have too much light to see where your going esp when all these retards are running around with HIDs in stock headlamps (imports) blinding just about everyone and themselves.
Overall, good job! now enjoy them! I still get very excited to drive my car at night and to flip those HIDs on and get that beam and very sharp cutoff . best part is that the cutoff of the morimoto and FX-R projectors is better/sharper and has better light output than most of the newer BMW, audi, mercedes etc.
Old Jan 26, 2012 | 08:41 PM
  #185
sjgrimsley's Avatar
...By decreased the height of the projector you could have increased the height of the lense (Compared to how much is getting cut off from the bumper) which will put more light on the ground right in front of the bumper. You should take some pics on level ground of the light output within the first 15ft of the bumper.
Actually, your thread and idea inspired my thread and idea lol
I assure you and all others that the FX-R foreground limiter is so aggressive that there is absolutely no light being blocked by the front bumper. But, depending on how I sit in the car, you can't tell the limiter is there.
8000k bulbs? You'd be surprised how much usable light you will gain by getting some OEM 4300k bulbs in there. They will look yellow compared to what you have now but will still be very white once your eyes get used to them. That high of kelvin rating has much much less usable light that a lower rating. 4300k has the most usable light of all the color temps.
Actually, now that I'm used to the amount of light and have them adjusted perfectly, I would not step down to 35w. Mainly because of the amount of backroads driving I do.
I love driving at night! It looks stunning everytime the lights come on! Lol
Old Jan 27, 2012 | 01:06 PM
  #186
Car: 87 TA clone
I agree that the projectors are of good quality, i just wanted more of the projector lense above the bumper cutoff.
Reason I went with 8000K bulbs is bc of the 55w kit, the 55w kit will wash out the bulb to about a 5500K to 6000K bulbs, therefore decreasing the kelvin of the bulb and putting out more/better light. If i went with a 4300K bulb with a 55w kit it would have washed out the color of the bulb and made it even yellower. Im not into the yellow look of headlights, reason is that the HIDs look great with crisp white light and the cutoff gives it a beautiful rainbow like cutoff. If ive left alittle bit of light on the table then so be it bc i drive in a very urban area and the roads are lit pretty well. I did get a pair of 6000K bulbs as spares so i can test different temps to see which i like best, the 6000K bulbs should wash out to a 5000K bulb nicely which will give me alittle more usuable light. Ive just left the 8000K bulbs in bc they look good and they havent burnt out yet lol.
There is a noticeable difference in light output from the 35w to 55w kits, and I would use a 55w kit if you got a good projector thats vented. However for fog lights and retrofitting into halogen projectors/fog lights/regular lights I would stick with a 35w kit as the heat generated by the 55w is alot. Im going to put either a 4300K or 3000K 35w kit in my projector fog lights and point them lower than my Low beams to get alittle more light in front of the car.
Old Jul 10, 2012 | 06:06 PM
  #187
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
Originally Posted by INTIMIDATOR Z
my buddy has these on his vette. personally i wouldnt have spent about $1k on these things (and not even finished) but to each their own. i call it a transformer
These light are sick I hate the single projector it looks like an eye ball and when you have the pair like on the vette it takes that eye ball look away and gives it a more modern look with high beam and low beam if someone could make a dual projector pop up head light I would buy it and maybe make fog light projector to
Reddeath210
Oct 6, 2015 08:20 AM
Out-Cast
Aug 22, 2015 07:49 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
BikeFarm
Aug 11, 2015 11:35 PM
drathaar907
Aug 6, 2015 04:20 PM
