Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Spy license plate
Old Jun 17, 2012 | 10:36 PM
dairy's Avatar
Car: 90 Camaro
Engine: 305 TBI
Transmission: 5 speed
Axle/Gears: 3.42 POSI
Spy license plate
Need a way to get the rear license plate to fold down at the push of a button. I figured its allready got all the springs and stuff that you need. All I need is a motor and switch.
The only idea Ive got is use an idle air control from a car some how. If you could get a switch to send power and push it out all the way and push the plate down and then cut the power or something and it would fold back up.
Any crazy helpful ideas?
Old Jun 17, 2012 | 10:51 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Spy license plate
Put one of these on a lever system. Easy as pie!
http://www.firgelliauto.com/show_info.php?page_id=35
Old Jun 18, 2012 | 12:32 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
running from cops? just make sure the car is fast enough first lol.
Old Jun 18, 2012 | 06:53 AM
Recaro trans am's Avatar
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
^^^^ Agreed^^^^
Thats some funny S_ _ _.!!. Maybe he's lazy and does not want to get out of the car for gas?
Old Jun 18, 2012 | 10:30 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Since the third gen plate position is difficult (Camaro and Firebird are mounted in different locations), there's no easy way to make a custom look. It sounds like all you want it for is to fold down as you go past a photo radar, I'd say you're on your own.
There's a lot of custom applications for the custom old car market. I know there's an engine vacuum operated fold down plate. When parked, the plate folds up under the car for a nice smooth custom look at the rear. When the engine is fired up, a vacuum signal from the engine is sent to the rear and unfolds the plate for display while driving. As long as the engine is running, the plate is displayed.
Old Jun 18, 2012 | 11:33 AM
white1991rs's Avatar
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
you should watch the mythbusters episode where they try to beat the speed camera
Old Jun 18, 2012 | 11:47 AM
BADNBLK's Avatar
COTM Editor
Door lock actuator... most have 3/4" throw. Not sure how you would mount it though.
Old Jun 18, 2012 | 05:17 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
How about a really long choke cable? just fab up a little linkage setup
Old Jun 18, 2012 | 08:55 PM
dairy's Avatar
Car: 90 Camaro
Engine: 305 TBI
LOL thanks for all the coments and ideas. The main point of it is to just be able to say I have it, that and you just never know when you might use it.
Oh and I have seen that episode, not too bad.
Old Jun 18, 2012 | 11:16 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Depending on where you tap in, there's no engine vacume under WOT, so in theory, if you went with vacume it would automatically flip up when you floor it.
May prove useful o:-)
Old Jun 19, 2012 | 01:04 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
http://www.plateflipper.com/photos.html
this is the one i have.. with You Lose! under it
Old Jun 19, 2012 | 05:35 PM
Guest
Guest
Posts: n/a
LOL @ anyone that believes mythbusters. :rollseyes:
This could come in use for IPASS or automated toll systems, and red light cameras. :O
Old Jun 22, 2012 | 08:47 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Wouldnt it be easier to mount it to something that would slide up into the trunk? Could even have a plate put behind it (make sure its firebird or camaro tho, so cops have harder time finding you!)
Old Jun 22, 2012 | 11:03 PM
dairy's Avatar
Car: 90 Camaro
Engine: 305 TBI
The main reason I had this Idea was because its allready set up to fold down so you can open the hatch with the key. You could still put a plate behind it.
And the plate flipper seems like a good place to start for only 50. You have any pictures or anything of yours?
Old Jun 22, 2012 | 11:52 PM
Car: GTA
For the front, I wanna see another Camaro guy do this:
http://www.hotrodders.com/gallery/sh...cat/500/page/1
Old Jun 23, 2012 | 05:07 AM
mines off right now. doing some car upgrades (every thing)
the Video is down right now.. but hit the button or if you like, switch and the plate pops/flips down.. hit it a 2nd time and the plate pops/flips back up..
bolt on easy set up.. no cutting.
the link blackendbird posted shows a slick front plate set up..i like that one! (i dont run a front plate) my self but would with somthing like that.
Old Jun 23, 2012 | 03:54 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
That might be the coolest exterior mod to date. I had a thought for my firebird that would slide it out from under the bumper and then up. Still wouldn't be as awesome as that
Old Jun 23, 2012 | 10:32 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
i didnt know they even made the motorized plate flippers. Im gonna look into that one. The hide away on the front of the red iroc is awsome. Id like to find out who he is and how he did it as hes local to me. Would be awsome if it can be duplicated
Old Jun 23, 2012 | 10:39 PM
Car: GTA
Ratchet is the TGO member that did it 7 years ago.....https://www.thirdgen.org/forums/body...-007-cool.html
Old Jun 23, 2012 | 10:49 PM
6SIX6's Avatar
Car: 89 IROC
Too bad hes not on here anymore and by the pics he posted you cant make out anything or how it was assembled to see how it went or I would make my own
Old Jun 23, 2012 | 10:51 PM
Car: GTA
Only been gone for 3 months so maybe still around & just not online. PM him & ask.
Old Jun 25, 2012 | 12:53 PM
6SIX6's Avatar
Car: 89 IROC
Im gonna pm him and ask as I have a friend that is a tool maker and has access to a CNC machine so maybe he can help us out with making the pieces
Old Jun 26, 2012 | 03:45 AM
Dakota W.'s Avatar
I'd like to know about the front plate hider for our cars too, it would be funny as hell to mess with cops. I'd just ride around with it hidden and then if I get pulled over pop it out. I can imagine it officer "Do you know why I'm stoping you today son?" Me "No, why?" Officer "you have no front plate, that's a $140 ticket!" Me "I think you should look again, because it was on there this morning." Oh man that would be awesome!
Old Jun 26, 2012 | 11:54 AM
Car: GTA
Originally Posted by Dakota W.
I'd like to know about the front plate hider for our cars too, it would be funny as hell to mess with cops. I'd just ride around with it hidden and then if I get pulled over pop it out. I can imagine it officer "Do you know why I'm stopping you today son?" Me "No, why?" Officer "you have no front plate, that's a $140 ticket!" Me "I think you should look again, because it was on there this morning." Oh man that would be awesome!
That would work until it was an Officer with a video camera in his car who had seen your car from head on & caught it on tape with no plate & he had u-turned to pull you over. Then he could still write the ticket & it would stick in court.
Old Jun 27, 2012 | 01:23 AM
NV/ID/WA/OR are all Fix it tickets. and if it's on the car your good.
on the car at time of Pull over/stop.
in the 20+ years i have had my 92 Z28 Never been stopped for not having a plate.. just lucky who knows
still never putting one on...Ever!
Old Jun 28, 2012 | 12:24 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Be even funnier when he told you it was illegal and towed the car lol
Old Jun 28, 2012 | 01:36 AM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
There's always the dashboard-plate-in-windshield. Did that with one of my birds and got pulled over 3 times by the same cop. He genuinely did understand why I refused to drill holes in the nose on my car. Always got the same warning.
Dakota, you'll be better off not messing with cops, even though it's funny. I finally figured out that they're so used to dealing with human garbage all day that if you treat them with respect, your minor traffic infractions get met with less than stern warnings. And if you're rude to them, they remember the car. Trust me. They remember.
Old Jun 30, 2012 | 09:48 AM
dairy's Avatar
Car: 90 Camaro
Engine: 305 TBI
I ordered the flip plate, hopefully it works well when it gets here.
Old Jun 30, 2012 | 10:26 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
No matter how fast your car is, it will never outrun radio.
Old Jun 30, 2012 | 04:36 PM
dairy's Avatar
Car: 90 Camaro
Engine: 305 TBI
Im not trying to outrun the cops.
Old Jun 30, 2012 | 09:40 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Hope you don't plan on actively using that because that can probably get you an action of police evasion in the right circumstances.. even if they're just pulling you over for a regular traffic stop.
I'd think REAL hard before using that if I were you.
Keep in mind: not having a plate, and intentionally obstructing your plates while police are profiling = two completely different issues.. hense why I say that.
Old Jul 4, 2012 | 10:29 PM
sum_drummer_16's Avatar
Car: 1983 Z28
Engine: Lt1
Transmission: t5
Axle/Gears: 4th gen limited slip
There is vacuum under WOT, vacuum just drops momentarily when the butterfly on the carb or throttle body snap open
Old Jul 4, 2012 | 11:38 PM
Car: White 84 z28
Engine: Chevy 350
That seems like a really complicated wayto go. And then think, you would have to floor the gas every time you see a speed camera or red light camera. How would you make it flip back? I think you should do it up on a switch. I know thats how im gunna... Allegedly
Old Jul 11, 2012 | 07:20 PM
dairy's Avatar
Car: 90 Camaro
Engine: 305 TBI
Finally got it installed. Pretty easy install once you understand the instructions. Works great.
Fronzizzle
Feb 9, 2017 09:31 AM
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
