Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
LS Swap alt. mount
Old Feb 20, 2012 | 09:57 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
LS Swap alt. mount
I had an idea to place my alt. in the ac comp. location... I was considering running it off of the ac belt on the crank pully. I dont plan on having a tensioner but instead using the alt. as the tensioner. Do yall think this will clear everything? Sorry about the pics, when i upload them it rotates them for some reason....
Attached Thumbnails LS Swap alt. mount-img-20120219-00067.jpg   LS Swap alt. mount-img-20120219-00071.jpg
Old Feb 20, 2012 | 10:53 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: LS Swap alt. mount
no there is a kmember there
Old Feb 21, 2012 | 07:00 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
things are really tight down there, which is why a lot of guys have to notch the kmember for ac. your + post would probably be in the kmember and that's a pretty big short you don't want
Old Feb 21, 2012 | 10:07 AM
Brando5641's Avatar
well isnt the alt. a lot shorter than the compressor is?
Old Feb 21, 2012 | 10:37 AM
xpndbl3's Avatar
Car: 1984 Z28
any reason you don't want to just use the f-body alternator mount like hundreds have done?
Old Feb 21, 2012 | 10:40 AM
Brando5641's Avatar
I am running truck acc. Power sterring pump is in the way... I have been thinking about pulling the powersterring pump off my camaro and tryen to make it work on the ls motor. I was going to try and mount it in the stock f body location and put the alt under it.
Old Feb 22, 2012 | 03:38 PM
Brando5641's Avatar
Update....
I just ordered the alt. and ps. brackets for a 2011 ls3 camaro. I dont know if my alt. is going to bolt up the same but if it will, i will use it and try to figure somthin out on the ps pump. If i cant make a 4th gen, 3rd gen, or truck pump fit in it i might scrap that idea and try somthin els. I thought about ordering a 5th gen pump but they are $100 and i dont know if my line will screw into it and if it has too much or not enuff pressure. I really dont want to just start throwin $$$ at this but if it works it might help out us folks running truck acc. I have herd that the ls3 (l99 has same brackets) has the truck acc. spacing is why i am tryen this.... We will find out.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
