Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Fiberglass Mold Over Plastic Plug?
Old Feb 20, 2012 | 10:42 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I'm looking at duplicating a part from a ABS style interior plastic peace...
I'v read some articles online... but i wanted to see if anyone else on here has done it, the steps, what they used, where they got there products from and the out come of there peaces...
Old Feb 21, 2012 | 10:18 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: Fiberglass Mold Over Plastic Plug?
you can use fiberglass I have done this before mix up the fiberglass resin then cover the part with wax paper and pour the resin over the part then when it is dry pop it off sand it with 180 grit sandpaper to fit the old part
Old Feb 21, 2012 | 11:52 PM
FueledSoul's Avatar
Wax paper isn't going to work for what I am doing.
Old Feb 22, 2012 | 10:11 AM
Patrick Day's Avatar
You are right wax paper will not work. you need to use a release agent like maguires wax release for fiberglass molds. You need to use the original piece as a plug to make a mold then use the mold to make the piece. If its an interior piece I would suggest maybe using carbon fiber for a custom look. I haven't done it on an interior peice yet but have made plenty of exterior pieces.
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
sonu1975
Aug 11, 2015 08:38 AM
