Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Quarter panel removal
Old Apr 26, 2012 | 06:48 PM
herders's Avatar
Car: 1986 Firebird
Engine: V8 305
Hey All,
I have a donor car that I am cutting the quarter panels out of.
What can I use to cut them out? Any suggestions...
I have 4.5 in grinder - this will consume many wheels
I have a reciprocating saw - I think this is the opportune choice but I am concerned about the saw tearing and wrecking the pieces - is this something I need to worry about
Is a plasma cutter overkill...
Others??
Paul
Old Apr 26, 2012 | 07:35 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Quarter panel removal
They do make a cut off wheel for your grinder that should work pretty well.
Old Apr 26, 2012 | 07:40 PM
herders's Avatar
Car: 1986 Firebird
Engine: V8 305
Thanks for the reply.
I have cut off discs and do use them but I wonder if they may be consumed very quickly. That is an option.
Paul
Old Apr 26, 2012 | 07:55 PM
Edwardgp's Avatar
Engine: 454-350
Nice clean cut would be worth using up some cut off wheels IMO.
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Cutoff disks will be cheaper than saw blades because you'll also go through a lot of saw blades.
If you watch any of the car shows on TV where they're cutting out panels etc for rust repair, it's always done with cutoff wheels. Saw blades can cause too much damage. Plasma cutter is too hot and will warp your donor metal.
The only time you would need saw blades or plasma cutter is if you're in an area where a cutoff wheel can't access.
Old May 9, 2012 | 07:00 PM
herders's Avatar
Car: 1986 Firebird
Engine: V8 305
The reciprocating saw did the trick, and I may buy one myself it worked that great.
Paul
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Exxon Limited
Aug 9, 2015 08:13 PM
3rdgenparts
Aug 8, 2015 07:09 PM
