Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
8.5" rear end swap
Old Jun 26, 2012 | 12:49 PM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
8.5" rear end swap
Im getting sick of the 7.5" rear end and I did a swap a 8.5 out of impala 95 rear end on my '82 truck and Im loving it and Im thinking of doing the same to my '92 Z28,my z28 has full suspension with aftermarket aluminum driveshaft and Im concerned about the length of the driveshaft after the swap because I dont want to cut/weld it did anyone here did this swap? I searched for topics and didnt find any
Old Jun 26, 2012 | 05:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 8.5" rear end swap
Swapping into a truck with leaf springs is easy. Swapping any kind of non third/fourth gen diff into a third gen isn't quite so easy. The torque arm suspension doesn't easily swap over.
Old Jun 26, 2012 | 08:44 PM
83RDRACR's Avatar
I put a zr2 rearaxle in my 83z and had to shorten the drive shaft 1 1/4 inches. I built a custom 3 link so no torq arm issues for me. Check this forum under home brew road racer.
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
