Dash swap
Car: 82' Z28 Crossfire
Transmission: Turbo 350
Dash swap
My 3rd gen dash is shot, so I'm putting a 4th gen dash in it. I have one problem though, I have an 82 so it is a carb with no computer. What would I have to do to make the electronic gauges work on it?
Re: Dash swap
Sorry if this comes across as rude, but I'm not looking for opinions. I just want to know how to do it.
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Re: Dash swap
Don't listen to that guy. Getting the gauges working would be hard. I'm sure it could be done, but I would suggest to install some aftermarket gauges in there instead of what there . this way you have the new dash with the shape and something else different then anyone else. And I think it would look better, kind of race looking.
Re: Dash swap
I would love to do that, but I dont have the money for the gauges. I'm trying to get these to work until I can afford new ones.
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: Dash swap
One suggestion that I might would make.. You will probably have to remove the printed circuit card on the back of the new guages. Then when you get a full schematic of your current 2 connectors, you would have to direct wire them into the dash.. This would be a very messy job and I am not positive the voltages would the same.. But, usually all guages run on a +12v system.. I wouldn't have a clue if the VSS is the same so the cruise might be an issue.
Car: 1987 Trans Am
Engine: 355 tpi
Re: Dash swap
well my first suggestion would be get a wiring diagram for what ever dash gauge set you have. The oil, alt, and such should not be to much of a problem wiring the fuel gauge my be tricky since the fuel sender is wired differently, but the hardest one is the speedometer. as yours is mechanical and the one on forth gen is electrical. and has a sensor on the trans. And I don't think the th 350 can be adapted for that sensor. All I could say is find one off a 700r and see if it will fit what you have. I know others on this site made the 4th gen dash work with a 700r trans , I know you don't need an ecm for the gauges to work
Re: Dash swap
Thanks! I'm definetly going to start ripping the dash apart and looking into it. If anyone has anymore ideas please share!
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
Re: Dash swap
This might sound rude but I don't care. If you don't have money for gauges then you don't have money for this swap. Getting electrical gauges to work for your car is expensive! So until your not broke forget it!
Re: Dash swap
Taking my finances are none of your business and you are not contributing to this thread at all, but rather just causing me a headache, gtfo?
Car: 82 z28
Engine: 350 carb
Transmission: 350
Axle/Gears: 10 bolt 3.42
Re: Dash swap
Dude give the kid a break!! He's customizing his car wit what he has available. The art of custom cars was never intended to be about who has the biggest bank account!!
Re: Dash swap
He got rude before I did. I was just trying to save him a headache but like I said I don't care, if he wants to tackle it more power to him.
Car: 82 z28
Engine: 350 carb
Transmission: 350
Re: Dash swap
Well I'm just going to say this. He has 3 parts cars an 85,92 & 94. You really need to watch how you talk to people's kids & how you react with them. Looks to me that your one of the guys that hides behind a computer. I can also tell you that if you were in Texas I'd be happy to meet with you & tell you how you will talk to & react to MY KID!!
Car: 82 z28
Engine: 350 carb
Transmission: 350
Re: Dash swap
Well I can say he is my kid & one of the best I know. You can talk as much about me as you want but when it comes to him you need to back off!!
Re: Dash swap
Odometer, yours mechanical, 4th gen digital. Speedo, yours mechanical, 4th gen electrical. Price the conversion parts and tell me if it's cheap.
Re: Dash swap
I didn't know I was bad mouthing anyone. I just replied to a smart*** comment w/ one of my own. For that I'll apologize as I didn't know he was kid.
Car: 1987 IROC-Z
Re: Dash swap
Another option would be to look at Dakota Digital for the Electronic Sender for the 700r4.. I don't know on the otherhand if it has the same PPM that the newer dash requires
Car: 82 z28
Engine: 350 carb
Transmission: 350
Re: Dash swap
As far as the 700r4 sender... I have the 92 parts car with a 700r4 that had an electronic cluster so if that sender will fit a th350 & operate th 94 speedo that would be awesome. I was just thinking the cluster may have been running through the ECM.
Car: 1987 IROC-Z
Re: Dash swap
I have seen that before in some wiring schematics.. The only thing that I seen on the 3rd Gen running through the ECM is the VSS for the cruise.. I will try to get on my mitchell manual later and dig through the schematics and see if the 4th gen's are the same.
Car: 1987 IROC-Z
Re: Dash swap
Here are what I pulled off the Chiltons for a 95 Camaro wiring diagrams.. This doesn't break it down wire to wire.. But you can see on the one where the VSS is run through the ECM and it does show that it is a 4000ppm requirement that is on the 88146w07.pdf file
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Dash swap
PATC. They (and others) sell a cheap trans adapter that will give you the signal you need for the speedo.
This (dash swap) has been done a number of times on third and second gens. If you can't find the info you need, I can link you to woody's swap which is one of the more detailed I've seen.
-- Joe
-- Joe
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: Dash swap
The vss runs to the ecm on newer tpi cars, then to the cluster and cruise control from there, same with v6, the newer tbi cars use the vss buffer box, earlier cars dont apply as they used a 2k pulse vs the 4k pulse needed for the 4th gen IP.
You'll need the vss buffer box from an 89-92 TBI camaro or firebird, which 4th gen dash you use will dictate the rest, 93-97 will use the same fuel sending unit resistance and tach signal, 98-02 doesnt, if you want the 98-02 style i'd get the dashboard but grab the IP from a 97. Oil pressure and Coolant temp senders would be a good idea also.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Dash swap
-- Joe
Car: 93 240SX
Engine: LQ9
Car: 1987 Trans Am
Engine: 355 tpi
Re: Dash swap
If you find out how to make this all work, maybe you could do a thread here with pics . So you could help out others that may want to do this swap. Isn't that what this forum is supposed to be, helping each other and advancing our selves and cars
Car: 1987 Trans Am
Engine: 355 tpi
Re: Dash swap
I did a search in the transmission section here on TGO and used the search for th350. I found out the sensor and speedometer gear from a 5speed will fit the th350.
Car: 1987 Trans Am
Engine: 355 tpi
Re: Dash swap
I did some more searches here and went to engine swap, Looked up efi to carb, and it seams you just need the vss buffer box and wire it directly to the speedometer.
I hope this may help
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 1987 Trans Am
Engine: 355 tpi
Re: Dash swap
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Dash swap
If he swaps to a 4th gen dash, he's going to need a electronic signal compatible with the new cluster. My recommendation is to buy a TH350 electronic speedo that is adjustable from PATC, rather than locating a stock one, matching up the gear teeth, wiring a 4 out buffer, then hoping the 4th gen dash takes a 2k or 4k.
On my thirdgen I'm running a dakota, sgi5 or something like that I think it's called.
-- Joe
Car: 1987 Trans Am
Engine: 355 tpi
Re: Dash swap
Maybe I'm forgetting, but if I recall an '82 camaro has a mechanical speedo to the cluster, with a VSS out of the cluster to the ECC.
-- Joe
-- Joe
Yes thats why I posted earlier that he'd need to get that from a 5speed, it will bolt up to his th350. I did a lot of research here on TGO to get the answeres and to guide this person where to look and verify what I'm saying
Car: 1991 camaro rs
Axle/Gears: stock
Re: Dash swap
if you can get an adapter for the tranny vss, the buffer box will work. i hooked one up to an s10 digital cluster and it worked like a charm.
Car: 93 240SX
Engine: LQ9
Re: Dash swap
-- Joe
-- Joe
Painless wiring 4k sensor threads right in place of the speedometer cable, has the same pulse as a stock newer model thirdgen vss, goes into the buffer, splits the signal to the 4k output that is needed for the 4th gen cluster and outputs a 2k pulse for cruise, or stock ecm.
Car: 93 240SX
Engine: LQ9
Re: Dash swap
Here is the sensor you need, the vss buffer you can get at the junkyard for a 90-92 TBI camaro or firebird.
http://www.summitracing.com/parts/PRF-60116/
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Dash swap
Why not run the 4k directly into the speedo? Didn't know he had cruise and needed the 2k..
-- Joe
Car: 93 240SX
Engine: LQ9
Re: Dash swap
#350E. Kit to convert your TH350 transmission to an electronic speedometer. This is used when your vehicle has an electronic factory speedometer and your transmission was converted to a TH350 gear driven type speedometer. This kit consists of a 8 pulse generator and an electronic ratio adapter to adjust the signal. Can be used to drive a speedometer cable at the same time. Cost $228.00
Unless you are referring to a different sensor they offer ?
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Vintageracer
Aug 11, 2015 08:13 PM
Save yourself a nightmare and forget about it!
