Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Hurst Quarter stick install and and mods
Old Sep 16, 2012 | 06:27 AM
Planert360's Avatar
Car: Z28 Camaro
Engine: 383
Transmission: TCI Th350
Hello all, new guy here, havnt posted much other then my Project thread (Project!) but figured someone might find this neat and not see my project, so here we go.
This is how I installed my Hurst Quarter Stick shifter.
First thing I had to do was remove the old shifter. I decided to utilize the plate that the old shift used so mine would be easily removeable if needed. I cut off all the old junk and was left with just a base plate (I forgot to take a picture, but I just removed all the crap...)
when I mocked it all up in the car, I didnt like how low the shifter sat compaired to the top plate of the center councel, so I did some measuring (guessing) and did some welding on the shifter plate, the final result after the flap disk and paint
then I threw it in to see how it would fit
with the shifter
now since the shifter wouldnt fit in the old shifter plate, I cut out a rectangle, basically where the gear indicator was
and the final result, fits perfect, olmost like I seasured it (but honestly this was all guess work after a few beers)
I also plan to add something to fill the gap. Im thinking something like those brisles you find on the snow scrappers for cars. this pic is what would be above those bristles, so basically what youll see in the end
Only issue I am running into is Ill have to drill a new hole for the shifter cable, also where the shifter cable goes through the shifter, will get in the way of the ash tray
I ended up cutting some of it out, but plan to add a thin sheet of aluminum in the ask tray and figure out how to cram a few toggles in there.
Let me know what you think!
Old Sep 17, 2012 | 08:31 PM
Planert360's Avatar
Car: Z28 Camaro
Engine: 383
Re: Hurst Quarter stick install and and mods
100+ views, and no comments?
Old Sep 20, 2012 | 10:24 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
I just bolted mine to the floor with three specific lengths of 3/8 brake line to get the height and placement I wanted and didn't have to cut out the whole gear indicator out.
Old Sep 20, 2012 | 02:33 PM
Planert360's Avatar
Car: Z28 Camaro
Engine: 383
that looks good, however it looks like it would site to high. mines perfectly level with my elbo on the arm rest.
Old Sep 20, 2012 | 02:51 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
If you look where the reverse handle it's the same location as you piece of cardboard. My arm rests on the pad also. I just didn't want to butcher the cover panel as I wanted it as stocklooking as possible. If you where worried about height the Megashifter would have been a better choice. I had one that ran my th400,th350 and also the powerglide with some small fab work.
Old Sep 20, 2012 | 05:15 PM
Planert360's Avatar
Car: Z28 Camaro
Engine: 383
ahh pictures can be decieving, it looks as if the bottom of your shifter was just under the plate, and mines a few inches. I kept with the hurst because it came with the car. also with the plate we fabed up im glad i got this one cuz everything fits perfect. also i didnt mind cutting out the shifter plate as i dont have over drive, and im getting an LED gear shift indicator to be spot on accurate.
Old Sep 23, 2012 | 05:19 PM
Planert360's Avatar
Car: Z28 Camaro
Engine: 383
Originally Posted by 1BADRZ28
Is that a screen infront of the HVAC controls? whats it for?
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
drathaar907
Aug 6, 2015 04:20 PM
