Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
vac can and ball relocation
Old Jan 28, 2013 | 04:17 PM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
not sure if I'm barkingupthe rite tree , I'm tring to clean up my eng compartment , already installed 4th gen windshield washer and overflow bott/bat tray , now looking for a spot for the vac can and ball ,any ideas? also took a power sreering cooler off a chevy truck and trany cooler that i will use for an oil cooler . on a budget but will put some cash in the rite places . not looking for a frankenaro .I can weld and make brackets for clean appearances. also using astro shaft and bearing . any other ideas besides the vac stuff? A little nervous about smog delete with proms ect ,not to good with tuning .
Old Jan 28, 2013 | 04:23 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: vac can and ball relocation
From the factory, the vacuum ball on my Camaro was mounted under the tray for the charcoal canister if I recall correctly? Either that or the battery tray but either way thats about as out of sight as it gets.
Old Jan 28, 2013 | 05:09 PM
Car: 1990 z28
Engine: 5.0
yes the ball is already hidden ,its the can that im wondering about can it be mtd upsidedown and still function properly?
Old Jan 28, 2013 | 05:12 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
It's just a reservoir you can mount it any angle you want
Old Mar 1, 2013 | 11:48 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I will try to mount this out of sight as well such as under the driver's side tray, as it takes up space where I want to put a window washer reservoir bottle.
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
