Welding Vortec 350 manifolds
Subscribe
Feb 23, 2013 | 03:41 AM
My current plan involves making the "back facing" exit point downwards for clearance so I can do a turbo project. They are off a 1996 Suburban with a 350.
First off, I'm wondering if these are grey or nodular. I honestly think I am dealing with grey iron here, just based on the way the metal behaves when I'm cutting it.
Second off, I need to add some steel plate to these. Is that going to be plausible to do without them getting crack prone?
Lastly, I have a MIG welder. I figured I'd get everything cut, make some nice tight gaps on it, throw it in the BBQ for a bit, MIG it up, whack the weld with a punch/hammer a few times then throw it back in the BBQ and let it burn the fire down. Any reason I should/shouldn't do it this way?
Reply 0
Feb 23, 2013 | 08:37 AM
Re: Welding Vortec 350 manifolds
The vortec manifolds won't fit a thirdgen
Reply 0
Feb 23, 2013 | 09:58 AM
I would say, forget it, you need nickel rod to weld gray iron.
Then it still might crack.
Reply 0
Feb 23, 2013 | 12:50 PM
Quote: The vortec manifolds won't fit a thirdgen
Thanks for the heads up don was afraid they were gray.
Fitment is why I wanted to cut and weld, also note I said turbo setup. I am going to flip, rotate and otherwise manipulate them. If I can weld them.
Reply 0
Feb 23, 2013 | 06:28 PM
ive welded them before but not with a mig,
we would heat them with a rose bud tig weld them up with nirod an then hit them with the rosebud again and throw them in a bucket full of sand and then dump more sand to cover them to make them cool slowly
never had an issue with them
if ur doing a turbo setup build logs like i did , flanges frm summit for 35 bucks
and get 8 90* weld els and 8 45* weld els use a 2.25 or 2.5 inch heavy wall tubing for the log sections they will outlast the car when u are done
Reply 0
Feb 23, 2013 | 10:27 PM
Most later manifolds are actually cast steel and weld quite easily without doing anything that special. That said, I have not tried welding vortec truck manifolds so u dont know for sure what ur dealing with
Reply 0
Subscribe
