Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
mustang 2 front end
Old Mar 3, 2013 | 01:27 AM
usertom5057's Avatar
mustang 2 front end
has anyone tried to put a long arm short arm front suspension in a 3rg gen camaro. i have a mustang 2 front suspension from a tube chaise and am going to tru to mock it up on my new project car when i pull the motor. i think i can use the factory lower control arm attach the mustang 2 spindle and upper control arm then cut a hole in the wheal well and attach the upper control arm to a custom made bracket that i will mount to the boxed out front subframe just inside the wheal well. i think i can drill vertically through the subframe and use some tubing to make a sleeve so i don't crush it when i bolt a bracket on to it that will serve as the upper control arm mounting location. the benefits of anti dive and camber gain will be worth the fab time if it will fit and i can get the geometry right. im worried about header and steering shaft clearance. anyone done this or have any suggestions???
Old Mar 3, 2013 | 08:46 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: mustang 2 front end
Saw a thread recently, perhaps in suspension, about a guy working (for over a year now) on a corvette front suspension mod.
-- Joe
Old Mar 4, 2013 | 07:49 PM
83RDRACR's Avatar
The problem with adapting most a-arm suspension to the 3rd and 4th gen front ends is that the top of the frame rail is very high. The upper a-arm would be more in alignment if it was mounted to the top of the k-member above the spring pocket. Mounting the upper arm to the top of the frame will have the angle of the arm pointing down towards the upper ball joint. This would cause a very undesirable positive camber curve as the suspension compressed while going through a corner.
Old Mar 5, 2013 | 12:53 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
someone built a 3rd gen for either Chumpcar or Lemons and used G body upper control arms and (i think) Caprice spindles.. the build thread is on this very site somewhere.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
bellez77
Sep 5, 2015 08:39 PM
