Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
material good for window guides?
Old Mar 9, 2013 | 06:12 PM
88rsbenjy's Avatar
Car: 88 camaro rs
Engine: stock 2.8L V6
Transmission: stock
Axle/Gears: stock
i used felt to cover the window guides as my original ones were scratching the window.
i hot glued them to the metal then hot glued another layer for added cushion.
is this a good solution or should i get the right ones from the store?
Attached Thumbnails material good for window guides?-549194_4499523054096_2049153044_n.jpg   material good for window guides?-429648_4499522174074_390507079_n.jpg
Old Jun 18, 2013 | 01:13 AM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Re: material good for window guides?
Probably just as good as the OEM style, though you really aren't gaining anything by stacking two of 'em.
Old Jul 19, 2013 | 03:17 AM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
that should be fine since thats what the original ones are they had felt on the ends to press against the glass
1992 Trans Am
May 10, 2023 07:19 PM
pfsteichen
Feb 9, 2016 06:59 PM
camaro71633
Sep 1, 2015 10:24 AM
Golfvette
Aug 24, 2015 06:35 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
