Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Fuel tank access door?
Old Jul 19, 2013 | 01:22 AM
Anthony Franz's Avatar
Car: Black 1991 Pontiac Trans Am GTA
Engine: 350 5.7L V8
Transmission: Monster Trans 700r4
When I first got my gta I replaced the whole fuel system such as filter injectors pump etc. when I changed the pump a friend of mine helped me and we cut a square above the tank in the hump in the car. I never ended up getting to put the original pieces back so I got a stop sign and cut it to size the used 3m tape to put it over the cutout, I did not want it welded incase I had to get back to the fuel pump. Anyways the tape doesn't really cut it to seal the cutout, should I be worried 1. about the structural integrity of the car and 2. gas fumes or anything like that getting into the car?
Old Jul 19, 2013 | 02:30 AM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
Re: Fuel tank access door?
Yes!...all the above, a friend of mine added some hinges and a layer of rubber to lock out the toxic fumes and tac welded a squared frame to support the body form possible twisting and even added Spohn body support which keeps the body from twist with high torque!...this is something I plan to do myself!
Old Jul 19, 2013 | 08:22 AM
Engine: 350 5.7L V8
okay thank you I was pretty worried I don't want to have anyone in my car get harmed and I don't want the car itself to get harmed so that's why I was curious about the structure lol
1992 Trans Am
May 10, 2023 07:19 PM
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
BlackTopKing
Aug 19, 2015 12:13 PM
AkDrifted
Aug 17, 2015 07:45 PM
