Crossmember help
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Crossmember help
I need a measurement if someone has there car in the air. I am building a cross member for my 4l80. The problem is my cross member is spanning from my subframe connectors not the stock cross member mounting points. I am looking for a measurement from each pinch rail to center of the transmission mount so I can make sure my drive train is in square.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Crossmember help
You should just measure on your car. Nothing about these cars are usually square at this point.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
What I am curious about is if the transmission is centered or offset in these cars.
Engine: 383 SBC
If I had to guess I would say slightly offset to the passenger side because that's how the motor is set in there for more steering linkage room.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Car: 89 Iroc
Engine: 305TPI
I completely forgot you asked for this. I will put a reminder in my phone to do it tonight and I will text you with what I find when I get it done. Sorry about that.
Evan
Evan
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Bump, I know Evan has allot going on. I tried to test fit my driveshaft and it wont clear my bmr track pak torque arm. I tried prying the transmission over but I am getting minimal movement. My engine is an ls engine with solid motor mounts. This is sitting on a pa racing k member. I know the transmission it to far over to the driver side but unsure on how much it is. I already loosened the engine mount bolts.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Well after doing allot of measuring I figured out the engine mounts on the k member are on there wrong. PA racing said they would re jig it up at no charge but I pulled the trigger on a motor plate and mid plate from aei. So I will get this figured out when the plates get here.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kammi10
Nov 9, 2015 08:28 PM
tmork454
Sep 29, 2015 06:33 PM
TOMcat GTA
Sep 15, 2015 09:31 AM
