Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
82-89 gauge cluster fix in a 1991
Old Apr 10, 2013 | 10:37 PM
Reborn91RALLY's Avatar
Engine: 5.7 carb
Transmission: TH350
Are the gauges in the 82-89 all mech or up to a certian year? Also can a older 3rd gen cluster fit in a 91.
Old Apr 10, 2013 | 10:52 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
Re: 82-89 gauge cluster fix in a 1991
you would need to swap the dash assembly out to 82-89 and get a mech speedo tailshaft assembly for the tranny
Old Apr 10, 2013 | 10:57 PM
Engine: 5.7 carb
Transmission: TH350
meaning i would have to change the whole dash? I have a TH350 trans
Old Apr 10, 2013 | 11:11 PM
Blue1990camaro's Avatar
yup you would, not worth the hassle keep your 91 dash
Old Apr 10, 2013 | 11:15 PM
Engine: 5.7 carb
Transmission: TH350
i like the the cluster it was to a v6. I know i have to changed it to the 145mph. Which is rare. OK. I can use the V6 harness for the gauges then? I do see on the harness i have the water pressure goes to the passenger side. I do have an oil and water mechanical gauges.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
ChevyZ71
Aug 13, 2015 07:30 AM
