bump stop for mini tub
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I have seen a lot of mini tub threads on here, but nobody is talking about how they make bump stops. how are you all doing it?
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: bump stop for mini tub
We're not running any. My car is not built for storing several hundred pounds of crap in the hatch anymore.
Engine: LS3
Me neither, but I am worried about going over big dips in the road fast and having the rear end dip. Ask me how I know this can be an issue!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
I remounted the stop to the subframe on the inboard side of the springs, by the fuel tank. Or you can use shaft mounted ones on the struts
Engine: LS3
I have the shaft mounted ones already. Was interested in what other people are doing that is not that
sjorgens
Oct 1, 2015 07:54 PM
