8.50 cert cage into a 86 Z28
Car: 1988 IROC
Axle/Gears: 3:27 9-bolt
Re: 8.50 cert cage into a 86 Z28
Looks good! Are you planning to put the interior back in the car? I ask because I installed my hoop in the same spot and now I'm afraid I won't be able to get the rear plastics back in.
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Interior will be going back in, we are going to weld most of it and before the main hoop gets welded to the floor we will break the tacks and sneak them in, because right now they wont go in.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Looks good. I was going to ask if it was a kit or custom made then I saw the JD bender.
I like cages where the halo tube is part of the a-pillar tubes and only uses a cross tube across the top of the windshield. They just look cleaner done that way.
Doesn't take much to get an 8.50 cert but it also doesn't take much to add in a few more tubes. Diagonal across the roof, sill bars and X tube in the door all serve a purpose but are not required for the 8.50 cert. I got way more tubes than required for the 8.50 but I know my cage will stay together and protect me if I ever put the car on the roof. I don't have a funny car cage mainly because it's not required and it makes it a real pain getting in and out of the car.
I plan on running in Edmonton a few Sundays this year. Just haven't decided exactly when yet. Car still isn't ready to race. Sucks not having a local track any more.
You would be better off running your rear kickers down by where the shock mounts than back where you have them going if it isn't already welded up. I would also straight bars, or a rear halo. Looks good!
Car: 92 Camaro Rs.R
Transmission: wc t-5
i may have missed it, but what tubing are you using?
i know for out weight our cars need .120 wall 1.75 o.d. DOM
Car: 87 IROC L98
In those first couple of new pictures, I was wondering why your door bars looked funny then I saw they were swing out bars. That eliminates the X door bar and funny car cage option but you could still put in sill tubes.
Only a 6 or 8 point roll bar requires 1-3/4" tubing in the main tubes. A full cage only requires 1-5/8" tubing for the main tubes. Many of the secondary tubes can be 1-1/2" or 1-1/4" depending on location and length.
0.134" ERW tubing or 0.120" DOM tubing. Our local metal supplier doesn't even carry ERW (special order) so whenever I pick up tubing it's 0.120" DOM.
Wish I had a TIG machine to make those pretty welds.
Car: 1988 IROC
Yeah, those welds make mine look like amateur hour.
Where did you get the hardware for the swing-out bars? And can you take some close-up pics of them? I've been eyeing the ones from S&W Race Cars, but they don't have a decent picture of them. I'm worried about clearance issues with the door panel on. TIA.
Car: 1979 Malibu
Engine: Blown LSx
Car: '91 GTA
Engine: 421sbc
Axle/Gears: Ford 9" with 3.89
Is this a business that is putting in your cage?
Care to share his name?
Car: 1979 Malibu
Engine: Blown LSx
Just a buddy that takes on selective projects in his garage. Not what he does for a living. Search cream dream v 2.0 on yellow bullet, or the Bavarian nightmare on yellow bullet to see more of his work.
Car: 87 IROC L98
That's another nice thing about doing the a-pillar and halo tubes like that. Most of it can be welded up outside the car then only a few welds need to be done inside the car.
Car: 1979 Malibu
Engine: Blown LSx
Yah, I'm extremely happy with how its turned out so far.
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
Looks good!
But are the swing out bars legal for competition?
Car: 1979 Malibu
Engine: Blown LSx
Legal to 8.50! This is primarily a street car, and with the new engine/trans combo in the works I'm probably going to run it out of cage in a hurry. When that time comes it will get a new chromoly 25.3 6.50 cert
Car: 1979 Malibu
Engine: Blown LSx
Cage is 95% welded. Just gotta weld the plate to the floor and the finish welding the cage to the plates.
Car: 1979 Malibu
Engine: Blown LSx
Cage is 100% done. Glass will be going in soon!
Started mounting the nitrous fuel cell
Threw on a front tire to check clearance on the fuel cell.
Car: 87 IROC L98
So how much did having the custom cage put in cost you?
Car: 1979 Malibu
Engine: Blown LSx
3 Gallon for the fuel side of the nitrous up front, 15 gallon for the fuel cell in the rear
Car: 1979 Malibu
Engine: Blown LSx
more updates!
nitrous fuel cell roughly mounted, may have to shorten up the cell a bit. Goign to put on the front fender and see how it fits.
Started removing the old front suspension
Driver side seat partially mounted
Car: 1979 Malibu
Engine: Blown LSx
More updates!
Rear bumpstops cut off and plated.
Kirkeys mounted.
Painless switch panel mounted on the halo bar.
Kirkeys mounted.
Car: 1979 Malibu
Engine: Blown LSx
Well, more updates... Last night was quite productive.
Brought the hood and front fenders to check clearance on the top of radiator.
Cut out some floor in the rear to make room for the fuel cell
Kirkeys
Radiator fits!
Nitrous fuel cell.
Welded a sump into the fuel cell
Rear wheel wells all cleaned up
Shot from the rear
Kirkeys
Radiator fits!
Nitrous fuel cell.
Shot from the rear
Car: 1979 Malibu
Engine: Blown LSx
Custom made master cylinder adapter
Torque arm bolted to the rear end.
Removable upper rad tie bar to make engine installation/removal easier
REAR END IS IN!
REAR END IS IN!
Car: 1984 camaro z28
Engine: sbc 383
Transmission: Th400
Axle/Gears: Moser 9", 4.11 gear
I'm not sure if you have ever answered this question yet and I missed it or not, but what are you looking to run when you get it to the track?
Car: 87 IROC L98
I need to do something like that but it would also require a bit more fabrication and relocation work because I have so much attached to and running across what I currently use for an upper rad support.
Car: 1979 Malibu
Engine: Blown LSx
With the 383, 11.40's is my goal on motor. Id like to.run mid 10's on the bottle. With the turbo motor in the works, it should run 8.50's pretty easily
Engine: sbc 383
Transmission: Th400
Sweet! Really nice work so far, cant wait to see what you do when you get it to the track.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I just did this to my car. I actually cut the whole rad support out and put the rad in the vertical position.
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Wow this is gonna look awsome when its done for sure. Cant wait to see it and how the interior will fit
Car: 1979 Malibu
Engine: Blown LSx
Made the car a roller again last night, so I can bring it home tonight. Nolan is gone for a week, so im bringing it home to keep going hard on it until he gets back to finish the fab work
New front steering loosely bolted in to make rolling it around easier.
Outside for the first time in a while
A picture a took when I was sitting in the car making engine noises.
Car: '91 GTA
Engine: 421sbc
Thanks for the updates!
When do you plan on hitting a track?
This summer?
This summer?
Car: 1985 firebird
Wow that's a nice piece! I have an 8point, like how you did the a pillar bars off the main hoop and tied em together with the halo, looks cleaner than a pillar bar welded to halo
Car: 1979 Malibu
Engine: Blown LSx
Thanks, I couldn't be happier with the cage!
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
you cut the tacks in strategic locations.
Car: 1985 firebird
Y'all do some real clean work!! Wish more fbody guys were like you instead of hamfist hackers early on. kinda gave us a bad reputation.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Second that. It seems like a small percentage of third gen owners don't just slap there cars together. Or there more worried about how to add cup holders to there vehicle.
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
Ingram...thats a nice lookin firebird.
It isvery rare to see nice 3rd gens. Usually every car i see is a wreck. Hell..mine needs carpet and paint soo bad i cant talk. LOL
