Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Vertical Radiator Mod
Old Jun 3, 2013 | 09:21 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Just thought I would post some pics of my vertical radiator mod. I wanted more room for the turbo and exhaust and figure this would be a good way to gain some room. I cut the center of the core support out. I then drilled out the lower spot welds. The lower support is built out of 1 1/2 inch square tubing. The upper part is 1 inch square tubing. This will retain the factory hood latch and require no hood pins. Radiator size is 16x31.
Attached Thumbnails Vertical Radiator Mod-core-support.jpg   Vertical Radiator Mod-core-support-1.jpg   Vertical Radiator Mod-core-support-2.jpg
Old Jun 4, 2013 | 09:38 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: Vertical Radiator Mod
Looks good, When I do my turbo setup I intend on just cutting the front section of the car off forward of the strut towers and im going to die the cage into it.
Old Jun 4, 2013 | 08:25 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
I have seen that done and it works great. Just could not cut up the car like that yet.
Old Jun 4, 2013 | 08:57 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
when i saw the thread title, i was thinking that someone had adapted an old school downflow radiator into their car for some reason... of course, GM did just that with the new Camaros, so i guess what's old is new, eh?
sheachopper
Jul 31, 2019 11:27 AM
