Power steering and alternator..HELP!
Car: 91' Formula/88' Formula
Engine: 5.7L TPI/ 5.7 zz4 with mini ram
Transmission: 700r4/Stock T5
Axle/Gears: 10 bolt 3.23 /9 bolt 3.70
Hi everybody.. It's been a while since I've posted but I've run into a problem and was wondering if anybody has pics of what you've done in this situation...
I have a 95 LT1 motor converted to carb, so I'm running the standard 6.75 sbc balancer with a march crank pulley (87' has 1 serpentine and 2 v grooves) this setup is in my 87 Trans am I want to use the 87 power steering pump and alternator (no a/c)
If anyone has a suggestion or pics.. Any help is appreciated
Thanks..
I also posted this in engine swaps...
Thanks..
Re: Power steering and alternator..HELP!
I've got an Lt1 in my Z28. Also planned on running v-belt accessories. Alternator will be down low on the passenger side, power steering will be down low on the drivers. I haven't made any bracket or templates yet so I'm really not much help yet. When I get that far (probably in the next couple weeks) I'll update.
Thanks, if I finish before you I will post the pics..
Car: '87 S/C Camaro
Engine: 5.0 LG4
Transmission: TH700R4
Not to raise the dead here, but can you use the stock third gen power steering pump with lt1 accessories?
Squeaky8791
Feb 5, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
