Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
T56 crossmember
Old Dec 20, 2013 | 05:32 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
T56 crossmember
Hello, I need dimensions for a t56 crossmember, dose anyone have a print by chance?
even a drawing with dimensions will work and i can produce a real blue print to post up for us all in solid works.
Old Dec 21, 2013 | 06:51 PM
Pocket's Avatar
Car: 91 Trans Am
Re: T56 crossmember
As simple as they are, just cut and weld some flat stock with the trans installed
Old Dec 21, 2013 | 07:21 PM
Chevy8588's Avatar
Re: T56 crossmember
God dammit why did YOU have to say that. Ive read alot of your threads and have a **** load of respect for your abilities, now I cant give you a cocky response, so therefore, I do not have the ability to do mock up work at the moment
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
kammi10
Nov 9, 2015 08:28 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
