Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Home brew sheet metal brake
Old Jan 3, 2014 | 11:43 PM
83RDRACR's Avatar
In building my home brew road racer I have come to the point where I need a sheet metal brake to make up to 90* bends in 18ga or thinner sheet metal with a max length of 28" for floor pan and firewall fabrication. Looking at my options The least expensive one I could buy new was about $400.00 and used ones were either very used, very large or both and very expensive to ship. So after looking at all of these on the web and in catalogs decided I could make one. Please note that before this I have never used a brake or studied one up close.
For the base I used the 1/2" thick steel plate on the welding table I made(see page 4 on home brew road racer for pics of table). The tricky part is to make a strong hinge that centers on the parting line between the bench top and the movable bottom plate. The hinges are made from some scrap 1/4 plate and short pieces of 1 5/8 roll bar tubing. work length is 29". I left a 1/2" gap on each side of the top clamp as I realized I could use it as a pan brake and bend 3 sides of a box. The whole thing bolts to the work bench with just 4 bolts.
I'll let the pics show the rest, any questions please feel free to ask.
Four major pieces
end view
Bending 18ga into 3 sided box
finished upper seat mount
Seat mount installed in car
Total cost of steel was $45.00. The top clamp is made from 4" x 1/4 angle and 1 1/2 channel. Clamping force is supplied by two 1/2" bolts. Clamp is lifted off table by double stacked valve springs from old engine.
I made the same seat bracket a few weeks ago by hand, bending it over the edge of the bench top. I can't tell you how much easier it was to make using the brake. It is my new best friend.
Old Jan 4, 2014 | 07:22 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Home brew sheet metal brake
I have not done much metal work myself but have made a few tools to help me out now and then. A friend I use to work with has set up a metal shop at home for auto restoration and I am familiar with the tools. Your brake looks like it is doing a good job for you and just wanted to thank you for posting pictures. Love looking at pictures.
Old Jan 4, 2014 | 05:12 PM
83RDRACR's Avatar
Thanks, I posted the picks thinking someone else could build same or improve on my design. I think many of us have built different tools rather than spend the big bucks for manufactured part.
Maybe we could get a sticky if there was enough interest and have members post pics of the tools, jigs etc. that they have used to fab up a special part. Many of us are doing the same, or similar mods so a tool that helps one of us could probably help many more.
Old Jan 4, 2014 | 07:08 PM
Edwardgp's Avatar
Engine: 454-350
Yes that would be interesting. I took an old pair of vise grips that I buggered up using them for a welding clamp. Welded on a 6" piece of angle iron on each jaw and am able to make some nice little bends with that.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
bellez77
Sep 5, 2015 08:39 PM
Clean87TA
Sep 4, 2015 11:23 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
