Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Access panel maneuvering
Old Jan 17, 2014 | 02:23 PM
JARLwhizzBang's Avatar
So I bit the bullet and cut an access panel in my 91 z28 because the fuel pump just recently went out. (Some background info before judging- I dont have a garage, I dont have a driveway, minimal tools, I am at least 40 miles from the closest usable garage Im 20 and unemployed trying to get my only car running so I can get on my feet. If you disagree with my access panel, you can just move right along).
So the panel is cut and all, but im having troubles getting the assembly out. Ive heard you can cut the panel bigger or cut the lines. Neither of which are pleasant. I also heard lowering the gas tank enough to wiggle it out, but that doesnt seem like a streetside friendly job.
Does anyone have any advice? *
Old Jan 18, 2014 | 12:02 AM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: Access panel maneuvering
If I was you I would bite the bullet and drop the tank. I know it's going to suck, but it might save you from really messing up your car. That's just my two cents though...
Old Jan 18, 2014 | 12:30 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
You have to cut the lines if you cut access panel no way to get it apart without doing so.
Old Jan 19, 2014 | 04:59 PM
Pocket's Avatar
Car: 91 Trans Am
The lines run all the way under the drivers back seat. You'd cut the whole rear hump out to get the lines out intact from above
Old Jan 19, 2014 | 08:18 PM
92rsvortec350's Avatar
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
You have to cut the lines and go back with high pressure fuel line and fuel injection hose clamps to connect them together.
kkirch15
Sep 30, 2015 04:44 PM
FormulaEngland
Sep 30, 2015 01:50 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
