Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Wheel well question for slick clearance
Old Jan 17, 2014 | 07:17 PM
chad378l's Avatar
Car: 88 Firebird Pro - S/P
Engine: 383
Transmission: Glide
Axle/Gears: Midwest 9" W/4.56
I bought a Midwest chassis fab 9" for my car. It was one they had in stock and was slightly narrowed to tuck the tire a bit. I started cutting my bump stops & trimming the inside. On the driver side it's a bit close. So I searched on here and looked at a ton of mini tub topics to follow.
I'd like to cut the metal away and expose the spring perch area, what would it hurt to weld and smooth it with the factory spring exposed? That would give me room I want because it sticks out right there
Old Jan 17, 2014 | 08:31 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Wheel well question for slick clearance
if your getting that close. i would start looking at your LCA's. to make sure your not going to rub.
as you move in on that part of the wheel well. you will start to run into the stock LCA's.
at that point you will have to go to a after market smaller diameter lower control arm. or even a custom offset LCA
NOTE: this pic shows. smaller diameter. LCA's with offset bushing. to bring it in away from sidewall of tire
this shot shows ya want to make sure you have a wall to keep spring from ever moving out to the side...this strap is 1/16" thick then thinner sheet added for cover...that ya dont have to do..
with sheet addedName:  sportsmen791.jpg
Old Jan 17, 2014 | 09:37 PM
chad378l's Avatar
Engine: 383
Transmission: Glide
Perfect. Thank you. I have a good 1/2" but I want more in case I ever want to use 10" slicks. I got the smaller LCA tubes & offset bushing already so I'm good there. I have to pound the front bottom in but that's no biggie.
Thank you...this is exactly what I needed!!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
kah992
Aug 19, 2015 02:55 PM
redmaroz
Aug 16, 2015 11:40 PM
