Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
what sand blaster / material should I buy?
Old Mar 9, 2014 | 06:56 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I am looking to sandblast a lot of parts as well as my engine bay. I have done this before with play sand and a handheld blaster gun. Horrible. .. what material is best etc.... I saw a pressurized blaster and aluminum oxide blaster media, good place to start?
Old Mar 9, 2014 | 11:54 AM
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
Re: what sand blaster / material should I buy?
I just picked up a big blast cabinet from TP Tools. They have a lot of American made products. They have been and will be around for a long time so you will be able to get consumable items in the future. They also have all kinds of different blasting media. I do not know what kind of budget you have but good tools are never cheap.
Old Mar 9, 2014 | 12:45 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
nickel slag. easy clean up. $3 to $4 a 50lb bag. will clean any thing off. and holds up for a long time.
i use this on all the guns i make/build. before parkarizing.
leavs a nice clean surface to work with. clean off with air and clean rag.
Old Mar 12, 2014 | 01:55 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
I have used black beauty from tractor supply. It is around $7 for a 50lb bag and shreds off paint in a hurry. I believe it is coal slag available in a fine grit as well.
Old Mar 15, 2014 | 11:14 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Black beauty works great on any hard steel like engine brackets frame but on body parts I use Dupont starblast and I never use play sand it has a lot of silca
Old Mar 15, 2014 | 11:55 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I'll add my vote for black beauty/coal slag also. Works great, can be reused several times and it's CHEAP. I built my blast cabinet out of an old refrigerator and use the smaller of the 2 Harbor Freight pressurized blasters. It helps make up for my smallish(for blasting) 30gal air compressor.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Sep 16, 2015 12:37 AM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
raymondandretti
Sep 5, 2015 05:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
