Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
automatic to t56
Old Aug 27, 2014 | 09:46 PM
mac86's Avatar
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
automatic to t56
i am going to change my car to a 6 speed manual from being an automatic. my only worry is cutting the hole in the floor. can anyone please explain to me either in words diagrams drawings or pictures on the dimensions of the hole i need to cut, and how to determine where to cut it?
Old Aug 31, 2014 | 10:11 AM
Pocket's Avatar
Car: 91 Trans Am
Re: automatic to t56
Bolt the trans to the engine and lift the tail housing as high as possible. Use a marker or scribe to mark the 4 corners of the shifter mount. Lower the trans and drill small holes on the marked corners. From above connect the 4 holes with strait cuts
Old Sep 1, 2014 | 12:03 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
When I did mine, I just measured the length of the transmission from bellhousing to centre of the shifter, then punched a hole that distance from the edge of the engine block, then bolted up the transmission and jacked it up as close as possible and started cutting the hole with aviation snips. It's really not as difficult as you think.
Lbibb
May 5, 2016 12:00 AM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
bjpotter
Oct 4, 2015 07:48 PM
