cold air intake question
Car: 1938 Chevy 2 dr Sedan
Engine: Dart400 AFR190 TPIS ZZ409 Big Mouth
Transmission: Gearstar 700R4 level 4
Axle/Gears: Moser 12bolt-Det Trac loc 3:42
What size rubber boot fits the oval shaped throttle body? I am limited to about 3.0 - 3.5" clearance between belts and fan will a 3.0" tube 18.0" max
length supply enough air? Thanks in advance
Car: '87 Z-28
Engine: LT1-topped 400
Re: cold air intake question
Couldn't tell you offhand, but you can figure it out pretty quick by wrapping a piece of string around it to get the circumference, then dividing by 3.14 to get the diameter of boot needed.
Engine: 4++,350 & 305 CIs
4" seems to work for me.
Thanks to both of you...
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
