Full fram insert for 3rd gen camaro.
Car: 1984 Camaro Z/28 T-Top
Engine: 350 roller
I have a 84 Camaro Z28 that I had a little boo boo with and now the front end is shot on it. I was looking at dimensions of a S10 frame and think it would fit into the mechanics of the body. But my question is, is there a frame that will fit better that will work width wise? I am able to do shortening of the frame so that it will fit but even the S10 wheelbase width is a half of an inch short of being as wide and not happy with that.
I have looked on several forums and stuff but all just have people saying put in SFC when that will not fix my problem.
I have looked on several forums and stuff but all just have people saying put in SFC when that will not fix my problem. Supreme Member
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Full fram insert for 3rd gen camaro.
interesting thought , not sure it could be done with out VERY DEEP pockets . I do know the S-10 frames are used on SHOEBOX ford's [1949-51] and SLED MERC'S . would like to hear reply's . good luck .
Engine: 350 roller
I will be sure to let everyone know how it turns out. And the cost is not that much to insert if you find someone with a straight frame it just about straight forward just a lot of labor.
Car: '87 Z-28
Engine: LT1-topped 400
Probably going to be more expensive and labour-intensive than just getting another clean F-body.
Engine: 350 roller
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
What do u want to do with it? Unless its rock crawling or something there is nothing you can do with the factory body and typically subframe connectors and roll cage. Adding the s10 frame will only add weight and complexity.
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
The body is damaged where the frame bolts up?
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
got on pro-touring did this with a 60's mustang. turned it into quite the monster.
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
the mustang i posted had the rocker panels welded to the frame. so.. technically... its a unibody..lol.
now.. none of this is to say it isnt a LOT of work to do and get done right. you would have to cut out a lot for the camaro body to sit correctly.
I spend a lot of time on Pro-Touring and Lat-G. What you have proposed is not an uncommon thing (I started building a new frame for a first gen camaro a while ago and cannot find the time to work on it, what with my job and my third gen and all).
However, if performance is your goal you want to use something other than the S10 frame. Cheap may be good, but they are crap for suspension geometry.
ambainb
Apr 25, 2016 09:21 PM
