Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Rear Diffuser, Front Splitter & Rear Wing
Old Dec 20, 2014 | 07:16 AM
  #51
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Rear Diffuser, Front Splitter & Rear Wing
I am also interested. Where does it mount? Would I be able to run one on my Formula without changing bumpers?
Old Dec 20, 2014 | 09:44 AM
  #52
BBSDesigns's Avatar
Car: GTA
Engine: Bone Stock 350ci HSR T-76 Turbo
Transmission: T56 6-speed
Axle/Gears: Stock
Slowly but surely the newly designed 3rd gen diffuser it's done.
Same dimmensions as the universal but with a more subtle, smaller radiused duck tail to conform with the rear bumper and thus keeping it under a more "stockish" look. I will post pics as soon I installed it on my friend's Camaro TT.
Now, back to GTA track time/Solo1 story.
I am shamefully happy to inform that my T56 is not broken and it never was...
What I thought was an internally broken to pieces tranny turned out to be a broken 1/2" inch 12 grade hex bolt on my chromemolly torque arm that was hitting the driveshaft union. But since the noise and vibration only occured during load only and nothing while turning the wheels by hand it completely fooled me that day into thinking that my T56 was a goner!
But wow, a 1/2" inch 12 grade bolt sheared like it was done by a knife, talk about torque!!!! only in V8's baby!
Ok, so I replaced the bolt, check this and that and headed for the track(road racing) last weekend and guess what another damage... the new EBAY master clutch pump was a goner. What a piece of $hit!!!! PLEASE dont bother buying "ebay brand" clutch pumps, this is my second one it's not a matter of luck it's just because they suck plain and simple.
Since racing season is over I will be addressing the clutch hydraulics issue, probabbly end up making a custom made cable clutch system(any thoughts on this matter will be appreciated), also will be deleting the wing and bite the bullet and rework the rear hatch in order to make a F40 style wing with cockpit adjustable AOT. The front splitter will definately be designed and installed. And will shave the 277lbs pounds to make it a flat 3000 punder contender.
The GTA currently weighs 3277 with a full tank, no driver and the heavy 1/8" stainless steel wing mounts. In order to get to the flat 3k lbs mark I will remove the curret wing and make the F40 style one, remove the stock GTA power(driver, with pump and all the whistles) seats (about 100-120 pounds) and replace it with a 20 pound Sparco unit. Replace the stock Kenworth/Mack like starter with a ministarter. Replace the cast iron H2O pump with an aluminum one. Replace the factory sealed iron heads with aluminum ones. Replace the T-tops with custom made lexan units. Cut the rear cat back and make a shorter side exhaust. And remove stuff like the wipers and unessesary things.
That should shave the 277's right? Suggestions?
Old Dec 20, 2014 | 10:31 AM
  #53
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by BBSDesigns
Slowly but surely the newly designed 3rd gen diffuser it's done. Same dimmensions as the universal but with a more subtle, smaller radiused duck tail to conform with the rear bumper and thus keeping it under a more "stockish" look. I will post pics as soon I installed it on my friend's Camaro TT...
Good deal Ed, will be ordering one as soon as they're ready...
- Rob
Old Dec 24, 2014 | 05:40 AM
  #54
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
So do you guys still have a website or ??
When are you becoming our 51st state??
-- Joe
Old Dec 24, 2014 | 01:20 PM
  #55
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Just some stuff you guys might find useful...
http://ecomodder.com/forum/403091-post100.html
CFD Models
1. Stock 1990-1997 Mazda Miata
2. Stock 1990-1997 Mazda Miata at a 4in Ride Height
3. Small Front Air Dam at 4in Ride Height
4. Small Air Dam with Splitter at 4 in Ride Height
5. Large Air Dam at 4in Ride Height
6. Large Air Dam with Splitter at 4in Ride Height
Note: The air dam and/or splitter is 2 inches off the ground in study 3-6
http://www.formula1-dictionary.net/ground_effect.html
http://www.formula1-dictionary.net/splitter.html
http://en.wikipedia.org/wiki/Automobile_drag_coefficient
https://www.thirdgen.org/forums/tbi/...0-vs-83-a.html
You can crunch some interesting numbers with all this information, I think.
The chart regarding horsepower lists Area times drag coefficient. Our frontal area is generally right around 2m^2 (in one of hte other links).
If you can SUPER streamline the car and have a firebird, you can get the cd down to maybe .30. The least aerodynamic of our cars is probably going to be nearly .40, but probably average out to be around .35 or .36 normally.
So for that chart, our best case scenario is the blue line, and our worst case scenario is between the green and yellow line, which the safest estimate being the green line.
The other thing to note, is that the splitter ideally is twice the length of the ground clearance it has.
Our front bumpers dont lend themselves to splitters very well, but if you made something removable for the track it would probably work well. Nuffnuff's splitter seems close to ideal except on the street.
But if you read through the page on splitters, and the page on ground effect, you can see a lot of interesting addendums to it.
The splitter is meant to control the amount of air going under the car. You then increase the volume under the car in the back of the car to create a net low pressure area. The only effective way to do all this is a belly pan setup with a diffuser. A splitter and diffuser alone I dont think will accomplish a whole lot, especially since our cars are bottom feeders and have a lot of air that just gets blown back up at the hood at the front of the car and there's so much turbulence UNDER the car. If you can smooth out the bottom of the car, there's HUGE potential for effective ground effect I think, without having to use huge spoilers.
For the record, it's my understanding that the huge drag racing spoilers that go straight back off the decklid are for getting rid of vortices coming off the back of the car. They greatly reduce drag but offer no downforce. They work the way the bump spoiler on a prius works, essentially, which is how our factory Camaro spoilers work as well.
This video also has some really interesting comments from the guys who designed the Porsche 956 and 962 talking about how the formula 1 method for ground effect downforce wasnt nearly as effective in full-bodied cars.
This is the Porsche 962 rear diffuser venturis
Attached Thumbnails Rear Diffuser, Front Splitter & Rear Wing-porsche_962_119_diffuser.jpg
Old Jun 17, 2015 | 04:43 PM
  #56
BBSDesigns's Avatar
Car: GTA
Axle/Gears: Stock
Thread update!!!! Finally replaced the fugly wing, now is F40 style!
Also did some hood louvers to help remove excess heat.
Attached Thumbnails Rear Diffuser, Front Splitter & Rear Wing-wp_20150613_17_29_41_pro.jpg   Rear Diffuser, Front Splitter & Rear Wing-wp_20150613_001.jpg   Rear Diffuser, Front Splitter & Rear Wing-wp_20150615_21_19_24_pro.jpg   Rear Diffuser, Front Splitter & Rear Wing-wp_20150615_21_24_44_pro.jpg
Old Jul 10, 2015 | 02:13 PM
  #57
BADNBLK's Avatar
COTM Editor
Looks good. Let us know about the diffusers
Old Jul 10, 2015 | 04:45 PM
  #58
BBSDesigns's Avatar
Car: GTA
Axle/Gears: Stock
Automobile drag coefficient - Wikipedia, the free encyclopedia
Flat Out In a Le Mans Winning Porsche 962 - /CHRIS HARRIS ON CARS - YouTube
Wow!!! GREAT INFO!!! THANKS!👍
Old Jul 12, 2015 | 10:33 PM
  #59
SilverChicken's Avatar
Car: 1986 Pontiac Firebird
Engine: 383 SBC
Axle/Gears: Hawks 8.8 with 4.10’s
Hood louvers! I'm guessing those are one-offs as well? I've been thinking about making/finding something similar as my car is carbureted and so sucks hot air from under the hood which becomes very noticeably heat soaked around town. I'd love Love LOVE to see those babies become available!!!
Old Jul 13, 2015 | 08:33 AM
  #60
95Cam86Roc's Avatar
Car: 86 Iroc
Engine: LS3
If you are looking for functional hood louvers then look no further. I recently purchased a set of these and the quality is top notch.
http://www.camarolouvers.com
Old Jul 13, 2015 | 09:53 PM
  #61
Engine: 383 SBC
I guess I should mention my car is a Firebird. Otherwise I'd be all over those!
Old Jul 14, 2015 | 10:17 PM
  #62
BBSDesigns's Avatar
Car: GTA
Axle/Gears: Stock
Are you interested in a pair just like mine or without the tow hook slot provision?
I made mine out of ga#18 stainless steel, one piece, laser cut. They are lightweight, crackproof, rust proof, flexible and work great sucking out heat.
Old Jul 14, 2015 | 11:35 PM
  #63
project89's Avatar
bbs any interest in sponsoring a car going to the silver state classic and boneville this year ?
Old Jul 16, 2015 | 05:39 PM
  #64
Engine: 383 SBC
No sir I would NOT need the tow hook provision.
Old Jun 3, 2016 | 07:58 PM
  #65
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
Old Jun 5, 2016 | 11:50 AM
  #66
83RDRACR's Avatar
Morrow, were you able to mount the diffuser without modifying the storage well in the cargo area?
Best one I have seen so far, The outer side skirts are a big plus.
Old Jun 5, 2016 | 12:05 PM
  #67
havacamaro's Avatar
Car: 86 camaro iroc z
Engine: 355 LT1 Full Roller
Axle/Gears: 9 bolt 3.73 posi
morrow has peaked my interest. did you go about making that front splitter? and how is it attached to the chin?
Old Jun 15, 2016 | 01:00 PM
  #68
Jackie_Gleason's Avatar
Duuuude! Where did you get or how did you make that front splitter? Looks awesome.
Old Jun 15, 2016 | 11:51 PM
  #69
morrow's Avatar
Car: 92 Camaro Rs.R
Yes the diffuser mound without any modifications to the rear floor. Exhaust however is another story.. I did fit the magnaflow up there though and dumped it through the diffuser,, thus creating a blown diffuser.... The splitter I made from crotch .. 1/2 high density foam.. Two layers of fiber glass then three layers of carbon on the lip.. Portion you can see... It mounts through the bottom up through the factory chin making it removable.. It is also molded where it meats the factory body smoothly.. All hand layed in my garage.. Measures 68x32 and covers the entire front end to the tires.. It is cut open to let the air dam through .. Also mounts to the core support.. We are currently trying to get them into production... The production model will be 100% carbon fiber hollow core and weigh around 4 or 5 pounds I would guess.. They would go for 900 or so a peice and would still be removable as well...
Old Jun 15, 2016 | 11:53 PM
  #70
morrow's Avatar
Car: 92 Camaro Rs.R
Old Jun 16, 2016 | 12:15 AM
  #71
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Any plans for a TA version of the front splitter?
Old Jun 16, 2016 | 01:11 AM
  #72
morrow's Avatar
Car: 92 Camaro Rs.R
If the Camaro one goes into production. Then yes
Old Jun 16, 2016 | 08:54 AM
  #73
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
My exhaust dumps before yours does, so I shouldn't have an issue with mounting it. If you need any more test dummies, let me know.
I'm really excited to see you progress with this, glad to see somebody wants to make their car a road racer and not a drag car.
How are you liking the R888s?
Old Jun 16, 2016 | 03:15 PM
  #74
morrow's Avatar
Car: 92 Camaro Rs.R
Best tires I have ever used ..... Period... So far the current aero setup is doing very well
Old Jun 16, 2016 | 05:04 PM
  #75
Car: 1989 Camaro RS
Engine: LH6
Good to hear, been wanting a set for my Vette wheels.
Old Jun 18, 2016 | 11:36 AM
  #76
morrow's Avatar
Car: 92 Camaro Rs.R
I would definitely get a set... With the set up I have right now ... I have yet to get them to even squeal... The car is extremely planted and the tires have a big part in that
Old Jun 19, 2016 | 10:24 AM
  #77
83RDRACR's Avatar
Morrow, thanks for all the great pics and info. This should inspire more of us to do the same or similar.
Old Jun 20, 2016 | 10:15 AM
  #78
morrow's Avatar
Car: 92 Camaro Rs.R
Thanks for the kind words man.
Old Jun 27, 2016 | 04:06 PM
  #79
morrow's Avatar
Car: 92 Camaro Rs.R
Old Nov 25, 2016 | 11:09 AM
  #80
nevernamed's Avatar
Car: 87 IROC
Engine: 434
Transmission: TKO600
morrow, any update on getting that front splitter into production?
I also like the rear spoiler extension that you did, any chance that will be produced?
Old Nov 26, 2016 | 10:02 PM
  #81
morrow's Avatar
Car: 92 Camaro Rs.R
Unfortunately the production of the splitter hasn't gotten any where .. Lots of companies want to do them for me but they also want the rights to them so I'll basically get screwed lol ... I do make the spoiler extensions and diffusers. The diffuser is a bit costly to ship though...
Old Nov 26, 2016 | 10:20 PM
  #82
BBSDesigns's Avatar
Car: GTA
Axle/Gears: Stock
Morrow,
I appreciate that you share with us your splitter, diffuser and wing extension with us, but I think is a bit rude to hijack another fellow 3rd gen member thread to offer your parts for sale. Maybe is me, but I call that manners.
Old Dec 2, 2016 | 09:09 PM
  #83
morrow's Avatar
Car: 92 Camaro Rs.R
Morrow,
No no. I was no trying to high jack anything from anyone. I simply posted pictures because that's what the thread is about.. I may learn something or what I did may give people ideas to do them selves. Many people know I was planning to get the splitter into production for a while and this member happens to be one of them.. Which is why he asked... Simple as that... I'm not trying to high jack a thread to sell parts... I honestly don't care about selling parts... I care about helping people with there cars.... Sorry bud
Old Dec 3, 2016 | 12:05 PM
  #84
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
So what ever did happen to this thread and BBSDesigns Splitter backers? After 2014 this thread took a huge vacation for about 1 year, then came back for a week or two and died again for 1 more year.
So thanks morrow for reviving this again. I don't see any pictures of anyone getting theirs or of BBS ever making them for others in the "aesthetic" version. Please update this thread properly guys. Otherwise thanks to morrow for at least keeping it going and bringing it forth to myself as "I would like" to be part of these group buys for bigger badder things on our 3rd Gen's. Otherwise I would not have found this thread...more than likely ;P ;P
So could we get a proper update of the splitters, diffusers and wing in a single post or maybe update the original. Never been a fan of updating threads through posts rather than the original post. Keeps it clean and easier to read all updates when they're in the original post with update tags. Easy to go back to page 1 for all info vs page 4 post #877 and page 7 post #1541. See what I mean? My build thread is coming soon, it'll be the cleanest build thread and most comprehensive of any on TGO. Just tired of the searching and researching needed on TGO when most info can be found on the front pages if people would take the time and update threads in a new fashion and get away from updating though posts. So make a new informative post, but then also post it to the front page with an update tag so I can read all updated info on 1 page.
Thanks guys. Either BBS or morrow. Either of you will be my go to guy for these things. I still want a set of extended a-arms and definitely want an aesthetic diffuser (since Drifting is my main goal I don't want it to work too good lol). Still a toss up of what I want vs what I need for the Camaro. Thanks guys for furthering the 3rd Gen cars into the future with these products and visions. Adios for now.
Old Dec 7, 2016 | 11:11 AM
  #85
Car: 1989 Camaro RS
Engine: LH6
Shipping the rear diffuser couldn't be that much?
Old Dec 10, 2016 | 09:32 AM
  #86
Engine: 383 SBC
I don't think anything was ever done for anyone. His last post was July 2015 in response to my inquiry obout the louvers and I never heard anything more nor purchased them myself. I did eventually get them, turns out 07-13 GT500 Super Snake louvers look and work FANTASTICALLY!
Old Mar 23, 2017 | 10:58 PM
  #87
morrow's Avatar
Car: 92 Camaro Rs.R
I still have a few sets of louvers 👍🏻
Old Mar 26, 2017 | 01:09 PM
  #88
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I know you've said it before, what louver is on your hood currently?
Old Mar 26, 2017 | 02:49 PM
  #89
morrow's Avatar
Car: 92 Camaro Rs.R
the louvers on my car are called the RsR louvers. I have three sets left pm me
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
AkDrifted
Aug 17, 2015 07:45 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
