Idea for Center Console
Car: 1986 Z28
Engine: 305 LG4
Transmission: TH700R-4
Hey there, I was doodling around and I came up with a custom center console design. Now, I would try this myself, but I'm a broke a** college student (lol), with ZERO skills for fabrication.
Tell me what you guys and gals think about the design
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Idea for Center Console
Sure, you can make a new center console and you can build it however you want. Over the summer I spent a considerable amount of hours trying to build one from scratch with a wood frame like so many trucks do. I learned that any center console you create (for these cars) will have to use the exact same external dimensions, meaning the sides, bottom, back and the back of the frontside will have to be exact copies of the original other wise it will not bolt in or fit in. The only way to make one and make it strong enough to stay together would be spot welding an aluminum frame and sides and upholstering it. Wood splinters and is too heavy and fiberglass would crack. If you want something different you would be best off switching to a fourth gen piece or to modify the top of the center console as I did.
https://www.thirdgen.org/forums/inte...ml#post5796517
Car: 1986 Z28
Engine: 305 LG4
Oi! Thanks for the input Tibo, that's a pretty sweet fab! I wasn't thinking about building from scratch, more along the lines of modifying preexisting console.
Thanks I'll keep that in mind when I get some more fab experience (and cash lol) XD
Axle/Gears: 10 Bolt 2.73 Open
Good drawing. I like it. I can see modifying a third gen piece to be more like your drawing. Pick up a shabby core at a swap-meet, and give it a whirl.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
