Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
92 rs build
Old Apr 20, 2017 | 11:01 AM
eoj's Avatar
eoj
92 rs build
The car started with a tbi 305. Now has a vortec 355 roller. Mmmmmm. Should be pushing around 400 hp.
Adding an 8 point cage after patching in the floors to tie the subframe together.
Old Apr 29, 2017 | 02:10 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: 92 rs build
While you have the car apart and ready to weld take the time to weld the metal pieces that are only spot welded together. The rails under the car come to mind. Your probably installing SFCs but still, couldn't hurt.
Old May 14, 2017 | 08:49 PM
eoj's Avatar
eoj
Re: 92 rs build
Yep, putting in SFCs. Here is where we are now. Floor done. Cage done. Working on interior.
