Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Just got into 3D printing
Old Feb 16, 2018 | 11:04 PM
  #51
potterc32's Avatar
Car: 1985 Pontiac Firebird S/E
Engine: 350, .5 lift cam, Holly 650
Transmission: Monster Transmission 700R4-2K stall
Axle/Gears: 4th gen 10 bolt, 3.42
Re: Just got into 3D printing
Not sure of the extent of the machines abilities. But I've always really wanted a bank of switches that go in the spots pictured. Can the printer make working switches? Or has anyone seen someone make a switch bank for these spots to be used with misc accessories (TCC lockup, electric fans, laser cannon, etc...)? I hate the idea of modding in some aftermarket switches if I don't have to. I love the factory look!
Old Feb 17, 2018 | 10:26 AM
  #52
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
The best the printer could do it print up the ***** themselves or the new plate insert.
You could easily add small switches and maintain a similar to factory look, I don't know what kind of switches you want so I can't go any further in depth into options.
Old Feb 18, 2018 | 07:07 AM
  #53
83 Crossfire TA's Avatar
Many product switches are just commodity switches with covers on them to look like whatever it is that you want. I've printed that kind of thing before for a power supply cover for my printer that I wanted to have a big red slider switch on and I just used a standard switch with a big red cover.
If you wanted to print the actual switch, you'd basically end up printing the plastic housing and have to cut out and form the contacts/metal parts and then fit them inside. I've had some luck with designing parts with captive metal parts (***** printed around a nut so that they have metal threads in them), but because of the way the process works, the contraction of parts as they cool... it's not an easy thing to do.
Old Feb 18, 2018 | 08:04 AM
  #54
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Not what potterc32 is asking, but I just read an article yesterday on some of HPs latest 3D printers...commercial stuff. They actually have the ability now to print circuits using conductive materials, and embed those circuits right into a part. Pretty wild stuff.
Old Feb 18, 2018 | 09:46 AM
  #55
Engine: LB9
Axle/Gears: 3.08
You can do that with retail stuff.
Old Feb 18, 2018 | 10:31 AM
  #56
potterc32's Avatar
83 Crossfire TA, So if i just went and got a few push button switches of the appropriate size, I could have some switch "faces" printed and then attach them to the buttons. Is that what you mean? I wouldn't mind that at all.
Vanilla Ice, Do I need to come up with a sample switch cover to send to you to copy? I would want 6 or 9 of them. If you help me out, there are a couple other items I would like (radio faceplate, and maybe even a parking brake handle). Can you print in different colors, or will I need to paint them? Sorry, I'm kind of new to all this 3D printing.
Old Feb 18, 2018 | 11:55 AM
  #57
DynoDave43's Avatar
No kidding. That's fascinating stuff.
Old Jun 4, 2018 | 05:01 AM
  #58
I'm sure that you're looking for something a little fancier than this, but this is the setup that I mentioned earlier:
A small pocket that a commodity SPST switch is designed to snap into.
what it looks like from the front
cover printed for the switch
Now I have a big red switch for my printer lighting
The whole thing installed on the printer power supply
You can print any color that you can find filament in, but if you don't want it to look 3D printed you'll need to sand it, prime it and paint it, essentially give it the surface finish you want.
FWIW, I do have some interior parts that I've made for my car as an experiment and as suspected, PLA isn't a great plastic to print them from. They seem to be holding up OK but the first 90* day this year was warm enough to warp them a little bit causing a plexiglass bezel to pop off. Unless someone wants to try to convince me otherwise I'll likely try PETG before trying the more traditional ABS solution.
In this case, it was a bezel for an Arduino powered programmable/progressive shift light that I have been experimenting with. It doesn't look any different now that it was exposed to heat, but it's not flat if you put a straight edge up against it:
Test fitting the original design to see how it fits up in the dash contours
Another angle
Sanded, painted and a smoked plexi lens added to it
Partially lit up at night (I set the shift rpm to something liow to gt it to show more lights at a lower rpm than normal, the leds go to orange then red, matching the atari dash and then they all flash when you it the shift point)
Old Jun 9, 2018 | 02:10 PM
  #59
TireSmokin''s Avatar
Originally Posted by Tibo
I made this myself but I never found anybody to print it for me. It's the Dash emblem that everyone wants $20-40 a piece for. Can you print it for me with a PayPal donation?
Send the file to me. I can make it from any material you like. Aluminum seems to be popular.
Old Jun 9, 2018 | 03:27 PM
  #60
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I'll send you a message.
Old Dec 6, 2020 | 04:03 AM
  #61
David Fleming's Avatar
Originally Posted by djwyman
something I think would be awesome if some one printed or made a file of is a plate where the ash tray(with or without the door) would go above the shifter for people who have b&M shifters and either don't have the stock shift plate to modify (like my self my whole console was missing when I bought the car so I am buying it piece by piece) or for those who do not want to cut the factory shift plate for some reason.
I need this complete cover except it needs to be for 1985 Firebird... 2568seven4488six
Old Jan 4, 2021 | 08:41 PM
  #62
bluiroc's Avatar
Car: 1992 RS, 1989 GTA
Engine: 5.0 TBI, 5.7 TPI
Transmission: T5, 700R4
Axle/Gears: 10 bolt 3:42, 9 bolt 3:23
I have read some great ideas on this. I bought my printer about a year ago. I read most of this thread. I will be learning with ABS, ASA, PETG and ABS carbon fiber. I learned about oil and gas resistant filament. In car temperatures do get about 120-135, a guess. ASA will handle the temps and are design to not fade from UV’s. My printer was a kit and no cabinet included. I built one so I can better control it’s environment. I will now be able to print with better materials that are hard to print.
Old Jan 4, 2021 | 08:51 PM
  #63
bluiroc's Avatar
Shielding extruder from a draft helps control printing temps
I used duct board and a hot glue gun
I got lucky and was given some polymer for windows.
Old Jan 10, 2021 | 10:58 PM
  #64
AstroFirebird's Avatar
Car: 88 Formula 350 and 92 Z28
Kinda basic, but it would be cool if someone made those plastic ignition and door key caps. I know you can get them cheap online, but being able to print them in a bigger variety of colors would be pretty cool.
Old Jan 11, 2021 | 11:04 AM
  #65
bluiroc's Avatar
Yes color match your car. I’m thinking TPU or another flexible filament. I must say though SLA, Resin printing would definitely give you that texture.
Old Feb 18, 2021 | 05:56 AM
  #66
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
Stuffs looking good keep it up. ive enjoyed watching this thread. Two things ive encountered to always want would be the 91ish trans am gauge trim rings and would be neat for camaro/firebird if the center console piece could hold gauges like the 1st gens had
Old Feb 18, 2021 | 06:52 AM
  #67
rgauder's Avatar
Car: 1987 Trans Am
Not to hijqck but I make aluminum trim rings.
Old Feb 19, 2021 | 04:05 PM
  #68
bluiroc's Avatar
I like that idea, very Kool. I put a vacuum and voltage gauges in a 2nd gen of mine. It was nice. Never was big on the a-pillar setup. I done SLA resin printing would do and better finish for this app.
Old Mar 15, 2021 | 02:56 AM
  #69
ktthecarguy's Avatar
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Hi there,
is anyone making the replacement Formula hood bulge block-off plate to make it a functional vent? I saw it in thingiverse, is anyone printing it? I would like to buy one.
Old Feb 1, 2022 | 12:30 PM
  #70
Silentient's Avatar
Car: 1987 Transam
Engine: 5.3L
Transmission: Th400
Axle/Gears: Stock 10 bolt 3.42s, soon to be 9"
Working on a Driver side 52mm gauge "pod" for the AC vent. Trying to make it OEM era looking. The OEM vents always looked out of place in the later cars so I'm not too concerned.
is there a way for me to access this design and print it? That's sick
Old Feb 1, 2022 | 12:36 PM
  #71
rgauder's Avatar
Car: 1987 Trans Am
I can turn the rings out of alu?minus with some dimensions
Old Feb 2, 2022 | 09:27 AM
  #72
Engine: LB9
Axle/Gears: 3.08
Sure, uploaded it for you. I don't remember how in depth this design was. I don't think there's an attachment method build into the model. This was just an idea I had. So don't expect it to be ready to go.
https://www.thingiverse.com/thing:5229248
Old Feb 13, 2022 | 01:24 AM
  #73
bluiroc's Avatar
Some very Kool ideas on here. The comment of gauges like the first gen is interesting. I am going to make a gauge pod for the hood on my 89 GTA. Another nostalgic touch of ol' school. I also am wondering about the front louvers on this hood. What if they could become functional ram air vents?
Old Feb 15, 2022 | 04:09 AM
  #74
Oliver667's Avatar
Car: Firebird (1991)
Engine: V6 189cui
Transmission: automatic
Has anyone considered printing 82-84 Firebird ground effects?
I really like them, but original ones would probably be really expensive and it would just we wrong to put those on my '91 V6 anyways.
So a 3D file for those would be amazing.
Old Apr 12, 2022 | 12:27 PM
  #75
cdoyle's Avatar
Just wondering, does anyone know of a STL for the manual window blanks that some cars had?
I converted my car to power window, but still have the manual window holes in my door panels. Would love to fill these holes with something that looks OEM. If there is anything that says Camaro that would be a bonus.
Old Apr 12, 2022 | 12:54 PM
  #76
Engine: LB9
Axle/Gears: 3.08
That's a cool idea, I may need this if/when I ever go back to power windows. Do you have a picture? I might draw one up when I'm bored.
Old Apr 12, 2022 | 01:10 PM
  #77
cdoyle's Avatar
I'm trying to find a picture of them.
I know I've seen Firebird ones before but not cant' find them. I'll keep looking hopefully I can find something. Would really like to clean up my panels.
Old Apr 12, 2022 | 01:16 PM
  #78
cdoyle's Avatar
Just found this post on the forum
https://www.thirdgen.org/forums/inte...oor-panel.html
something like that but for a Camaro instead.
Old Apr 12, 2022 | 03:36 PM
  #79
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
Looks like something I could do in the injection machine. Could even make and bond the steel retainer to the back like that too. Only issue would be the epoxy graphics in the middle.
Might try to make them just for fun.
Old May 28, 2024 | 06:51 PM
  #80
F41camaro's Avatar
I'm going to be creating a couple 3D printer files, also looking for good ideas.
I am going to make the convertible tonneau switch and a double din bezel or iPad dock bezel.
I was thinking a good formula hood insert.
Gauge pods.
Vert shoulder belt cap/guides
Speaker grills.
Seatbelt guides
Wheel lug caps
Center caps
Also thinking of an integrated piece for 91-92 TA lenses. This one is intense but doable.
Any other good ideas floating around?
l69 dual ducts
Old May 31, 2024 | 07:44 AM
  #81
bluiroc's Avatar
This why I have ventured into the 3D realm. Sometimes you want something different. the big thing to remember is that UV light and temperature is a big factor. choice your printing materials wisely. Is anyone using a Resin printer? I am still looking for a good one I can afford and still make decent size parts.
challenger71
Exterior Parts Wanted
Oct 27, 2017 06:15 PM
haps
Wheels and Tires
18
Mar 5, 2012 06:40 PM
johnlj
Oct 15, 2009 04:43 AM
MiScHiEf
Exterior Parts for Sale
Sep 9, 2009 10:13 PM
BigWhiteGTP
Feb 24, 2005 10:03 AM
