Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
5x120 to 5x120.65 wheel correction
Old Aug 8, 2017 | 03:30 PM
rgauder's Avatar
Car: 1987 Trans Am
I made a little tool today on a 1LE hub that I had to correct the bolt circle of a 5x120mm wheel to 5x120.65mm or 5x4 3/4".
Similar to what another member did here before, but I made a push in guide for the 1" 60 degree cutter to ride on. The previous member had screw in studs and so he came up with a different arrangement.
Old Aug 8, 2017 | 05:01 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: 5x120 to 5x120.65 wheel correction
Looks awesome! Are you willing to sell it when you are done with it? I could definitely use it!
Old Aug 8, 2017 | 05:53 PM
rgauder's Avatar
Car: 1987 Trans Am
Make me an offer.
Old Aug 8, 2017 | 07:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Nice job!
Looks like you machined down a lug stud?
