Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
l69 snorkels welded to a lg4 air cleaner
Old Feb 12, 2018 | 07:35 PM
thechad1's Avatar
I have a1984 berlinetta with a gm 350 ho with l69 air cleaner. I would like a 3 point strut tower brace but would have clearance issues with the dual snorkel set up.Has anybody ever welded l69 setup to the lg4 air assembly? If so would there be a considerable air volume loss? To add I have no ac.
Old Feb 12, 2018 | 08:07 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: l69 snorkels welded to a lg4 air cleaner
Because it's thin metal, I would stick to riveting, which I could swear was a common method used by GM.
Or fabbing a STB to fit.
Old Feb 13, 2018 | 11:33 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I would'nt bother.The L69 air cleaner base is basically the same as the LG4.Main difference is/are the snorkel/s.The passenger side is where is had a clearance issue w/my edelbrock STB, but i got it to work by putting the tubular brace on top of the STB.I think it just contacted the hood though.My old set up.
Old Feb 14, 2018 | 11:36 PM
NoEmissions84TA's Avatar
I'm with you. But, after researching this issue, I want the 3 point STB more than the dual snorkel air cleaner. There is less under clearance with Firebirds, TAs, and Formulas than Camaros. So since I will be installing a RamAir hood anyways, I will just use a 14" open element air cleaner and keep things simple. Firebirds also have no front grilles, so allowing the hot underhood air out is also more of a priority than the dual snorker air cleaner for me.
Gsoleski
Jun 13, 2015 09:19 PM
3rdgenparts
Nov 8, 2012 06:58 AM
84Camarodriver
Aftermarket Product Review
May 18, 2012 04:41 PM
